Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire Pressure Monitors
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      06-16-2005, 04:36 AM   #1
RachelS
46
Drives: 2006 325i
Tire Pressure Monitors..
When I get new wheels, are they inside the old ones. One guy says they don't have any inside each wheel, they are just sensors that watch tire spin.
      06-16-2005, 04:58 AM   #2
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
I believe that it's incorperated into the DSC system. It monitors the wheels spinning, if the tyre deflates, the "circumfrence" of the tyre is smaller and hence it spins faster and the DSC can read this...and warn the driver.
      06-16-2005, 05:08 AM   #3
RachelS
46
Drives: 2006 325i
thank you, no extras to buy when getting new tires and wheels
hoooray
      06-16-2005, 05:13 AM   #4
E90Fleet
South Africa
1311
Drives: BMW
The old systems used to be in the tires and actually cheked the pressure
The new systems use DSC to detect a change in the rolling diameter of the wheel due to a pressure loss.
You must reset the system each time you change the tire pressures or change a tire.
      06-16-2005, 06:08 AM   #5
RachelS
46
Drives: 2006 325i
thanks E90Fleet and Broken1
      06-16-2005, 12:02 PM   #6
RedStripe
RedStripe's Avatar
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
Does anyone know how to do this reset? Is this possibly a do it yourself thing? Is it a must go to the dealership thing? Thanks.
      06-16-2005, 12:06 PM   #7
johnfkitchen
29
Drives: 323is & 330i
You do it yourself. Page 80 in the Owner's Manual
      09-24-2010, 05:00 AM   #8
JustinS
Member
Australia
Drives: 335i, VB3s, MHD, FMIC, RBs
Not sure if I get it, why do some people talk about selling wheels with TPMS then? Sounds like it's not required anymore? Sorry, this probably a real newb question.
      09-24-2010, 06:37 AM   #9
cb1111
I ask the questions you're afraid to ask.
cb1111's Avatar
44
Drives: 335xi
Again, the misinformation is astounding. Can we please check the OP's location before answering?
For the US (and only the US)
TPMS sensors have been required in all new cars since the '07 model year.
These sensors actively determine the amount of pressure in each tire and report that to the car. Pursuant to the TREAD Act, the car must alert you if the pressure falls by 25% - i.e. if your tires are at 40psi, then the car must alert you NLT 30psi.
For BMW, the sensors changed with the '10 model year, so ask wwhat year the sensors came from.
TPMS sensors are small pressure sensors attached to the inside of your valve stems. They are installed at the time that the tires are mounted to the wheels. If retrofitting new sensors then the tire must be (at least partially) dismounted.
The rest of the world including Canada but excluding the US
Either uses nothing or it uses the "indirect" method where a change in the rolling diameter alerts the driver of a problem - like Broken1 explained.
The indirect method is too inaccurate as it merely senses a difference in rolling diameter. Accordingly, if all tires lost air (think long term storage) then you would not get notification. Conversely, the direct method would alert you to a loss of pressure in all tires.
In addition, the indirect method reacts fairly slowly and was not considered a viable alternative following the Explorer/Firestone debacle.
You will find the indirect method (called Flat Tire Monitor [FTM] by BMW) on some '06s and cars in Canada.
      09-24-2010, 07:43 AM   #10
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [8.24]
I think you got that flipped, I believe all cars 07 and up have tpms in the tires and earlier models than that used the DSC.
I have exhaust and an intake...
      09-24-2010, 09:15 AM   #11
Mr. ///M3 RD
Happy Camper
Mr. ///M3 RD's Avatar
612
Drives: C63 AMG & 280 SL on Weekends :
Don't you also have to check what CODE your car has by entering the VIN number into this link?
Car made for US or Canada Vin - CODE decoder here
Tire pressure monitoring systems as you say are different in the US and or Canada.
Also, if you change to winter tires with a new set of wheels you need the TPMS also in those wheels or the light on the dash will be on all the time (some people mount winter tires without the TPMS since it is quite expensive ranging from $200- to $400- for the car depending on the system, so I am told).
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too
---> Click here for some good stuff I found
      09-24-2010, 09:28 AM   #12
Bpinsm
Drives: 330xi
60 used the DSC. 07 and up uses a monitor in the tire.
      09-24-2010, 12:11 PM   #13
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
This thread is from 2005....
      09-24-2010, 12:43 PM   #14
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
Holy crap it is haha
      09-24-2010, 02:14 PM   #15
Mr. ///M3 RD
Happy Camper
612
so it is, I never checked LOL
Cheers, Rolf-Dieter
      09-24-2010, 02:19 PM   #16
cb1111
cb1111's Avatar
44
Drives: 335xi
At this point we all slap ourselves on the forehead - d'oh.
But to answer your other thread, it is more cost effective to get a second set of sensors for your winter wheels.
      09-24-2010, 03:00 PM   #17
Mr. ///M3 RD
Happy Camper
612
of course you are right I made the math also I don't like to disturb the tire otherwise I also am looking at new wheels balancing
Thanks for your post(s)
Cheers
Rolf-Dieter
Cheers, Rolf-Dieter
Search this Thread:
Advanced Search
