'06-08 Pre-LCI to LCI - Reverse Light Tint DIY
04-18-2017, 01:37 PM | #1 |
179
Rep 601
I just picked up these Pre-LCI reverse light tints from Slickmod.com
I picked mine up off eBay for about $14 shipped ... I figured what the heck, might be better/easier than spray painting and clear coating. The idea is for these to be an interim solution. Until I pony up the $$ for a Pre-LCI to LCI rear lights swap ... which is a bit down on the list of updates/upgrades. F Included is basic instructions, which are pretty straight forward. Regarding the "fit" ... they cover what they are supposed to, but I would prefer another 1-2mm larger; with about the same less for the cut out, widthwise. The additional material would aid in the overall fitment; insuring when the tints are shrunk, they will fully cover the lense edges. I did find myself having a bit of issues lining up the tints with the red bottom lenses perfectly. Being rather OCD ... it took a few attempts to get them nicely aligned. Not perfectly though. This is where 'if the tints were a little bit larger' would have been very helpful. Other than that ... make sure the lenses are clean of any lent, go slow, use a hairdryer to help it contour to the edges, after the tints are set where you want them. I found a microfiber cloth works nicely to smooth out air bubbles. If you are a bit OCD ... being able to say "close enough / that works" ... may be helpful. The color is a close match, not perfect ... but close enough to not warrant any raised eyebrows. Which goes for the fit too. It would take an inspection of a couple feet or less to notice they're tints. For $14 ... I'm more than happy with the results so far. The real test is to see how they hold up to the hot Florida sun and a "south facing" driveway. If they hold up for over a year - I'd be happy ... and happy to buy another set until I do the swap. |
04-18-2017, 04:55 PM | #2 |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
For about $5 you can get a small roll of red vinyl and cut it to size.
Probably the same as this except these are pre-cut.
04-19-2017, 09:07 AM | #4 | |
179
Rep 601
Yours came out excellent. I was about to go with spray painting them, but came across the tints. I figured, either way they'll likely need a reapplication. If the tints don't last but a few months, I'll likely go with spraying them. |
