04-18-2017, 11:46 AM | #1 |
BimmerPost Supporting Vendor
23784
Rep 190,103
Now Available Agency Power 340/440 B58 Air Intake
One of the easiest ways to gain horsepower and improve your throttle response on the BMW 40i B58, turbocharged engine, is with an air intake kit. Agency Power's new short ram air intake kit for the M240i, 340i, and 440i is a great first modification to do. The intake kit is a complete replacement for the OEM air box. The kit includes a new aluminum intake tube with CNC machined MAP sensor mount, precision cut heat shield with mounting tabs, and a new high flow air filter. The MAP sensor mount has been CNC machined out of 6061 aluminum to retain the factory fitment for proper readings. It is than TIG welded to the aluminum intake tube for proper placement. The main part of the intake is the high flow air filter. It features an inlet on the end cap to allow for an even larger volume of air to come through than a standard cone filter. The design improves air filtration while increasing air flow. The air filter is finished off with the Agency Power text and AP logo on the rubber end cap. The heat shield is water jetted from aluminum with rubber trim to provide a secure fit and seal when the hood closes. It is designed to prevent direct hot air from the engine being sucked into the filter. Each heat shield features the AP logo neatly cut out from the shield panel for added style. All parts are finished in a matte black powder coat for an OEM look while the cylindrical air filter features a blue element matching to the BMW Roundel logo. With the new air filter, your turbocharger can breathe better than the factory intake allows. This is noticeable as you step on the accelerator and hear the turbo work (sucking air noise). Release the throttle and the factory blow off valve noise (whoosh) is more audible and keeps you entertained through the gears!
Features: • Aluminum construction • CNC machined MAP sensor mount • Black powder coat for OEM look • Reusable high flow air filter Fitment: • BMW M240i F22 • BMW 340i F30 • BMW 440i F32 Note: • Heat shield was designed on the BMW M240i chassis and may require alterations or removal to work on the 340i and 440i. Part Number: AP-M240i-110
04-18-2017, 05:08 PM | #4 |
23784
Rep 190,103
I am not allowed to post prices here, i will send you a pm
04-18-2017, 05:50 PM | #6 |
23784
Rep 190,103
Based of Dyno done by VM on the BMS intake (similar style intake), gains are 5-8 whp
04-19-2017, 02:31 AM | #8 |
105
Rep 259
Drives: 16' AW 340i xDrive
Will there be a version for the 340i that is a direct fit? No modifications, alterations or removal of the heat shield for this application.
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
jalkster220.00 |
04-19-2017, 06:32 AM | #9 |
220
Rep 579
Would like to know this for the 3er...
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
04-19-2017, 07:45 AM | #10 |
1410
Rep 3,211
04-19-2017, 08:36 AM | #11 |
105
Rep 259
If the shield doesn't work then I would just look at the BMS. No sense spending 100+ on something you will toss.
04-19-2017, 10:38 AM | #12 | |
23784
Rep 190,103
Pm sent
04-19-2017, 01:05 PM | #13 |
23784
Rep 190,103
04-23-2017, 04:56 PM | #14 |
284
Rep 360
Would love to see a dyno sheet :/
2016 340I build thread : http://f30.bimmerpost.com/forums/sho....php?t=1266037
04-24-2017, 10:32 AM | #15 |
Captain Crunch
168
Rep 548
Agreed. Before and after dyno to back up the 5-8whp claims, please.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
04-24-2017, 03:12 PM | #16 |
165
Rep 413
I have the BMS intake with verified dyno gains for $100 less why buy this one?
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
04-24-2017, 03:27 PM | #17 |
Captain Crunch
168
Rep 548
Not to derail this thread, but do you have a link?
04-25-2017, 06:54 AM | #18 | |
165
Rep 413
https://www.x-ph.com/burger-tuning-2...billet-intake/
04-25-2017, 02:35 PM | #21 | |
23784
Rep 190,103
04-25-2017, 03:46 PM | #22 |
165
Rep 413
Pete getting aggressive
