CDV Delete: XI edition
04-18-2017, 08:14 AM | #1 |
109
Rep 235
This weekend I performed the CDV delete and noticed two issues I did not remember seeing before on any DIY guide. I'm not sure if this is common to all XI's or just MY2010.
The first issue is that according to all the other DIY guides you should be able to use a small allen wrench to pop out the internals (restrictor) of the CDV and put it back in place. The restrictor in my CDV is molded into the body and is one piece. I assume that BMW changed this at some point but I'm not sure when. I was forced to abandon the CDV all together. The second issue is that the clutch line hose is too short to connect to the metal clutch line without the CDV. I ended up massaging the metal lines enough to make it connect directly with the rubber hose line which worked out great. |
04-18-2017, 01:37 PM | #2 |
285
Rep 615
Drives: '11 E92 335xi 6MT
I read about the potential to stretch out the lines to remove the CDV entirely but decided I'd rather not do that.
Instead I bought the BMS modified CDV for $20 plus shipping. I'm pretty sure it was part of an order of a few things from BMS so didn't pay the shipping just for the CDV. Anyway, I later learned that the M3 CDV (part # 21522283914) is also a a pass-thru like the BMS CDV. So same deal, you replace the CDV with this and you don't have to stretch the lines. It's $12.31 at ECS. |
04-22-2017, 09:59 AM | #3 | |
31
Rep 143
Can you please explain how you made the metal line fit? And how do you like drive after the cdv Del? |
04-23-2017, 02:19 AM | #4 | |
109
Rep 235
I LOVE the way the car shifts now. So much better than before. |
04-23-2017, 07:14 AM | #5 |
179
Rep 527
Don't stretch the lines. It's a $20 part or you can drill out your old one. Not worth the chance of having the line come loose for the price, specially when we're driving bmw's. Then again as I don't like to half ass stuff, I wouldn't stretch a line with fluid in it on a huffy?
04-23-2017, 10:52 AM | #6 | |
109
Rep 235
04-23-2017, 09:30 PM | #8 | ||
179
Rep 527
