4x4! ABS Light transfer case actuator motor?
04-10-2017, 12:57 AM | #1 |
106
Rep 808
Idk if you'd be able to help but it's worth a shot. I have an 09 328i xdrive and I've had this light on. The brake light was never on, just the 4x4 abs. I diagnosed it using icarly and it said something about the transfercase. So I changed the transfer case actuator and the front wheels have power and they're moving but the light still remains and I've tried to erase the memory and no help. After erasing the memory I'm still getting this fault[IMG][/IMG]
04-10-2017, 11:34 AM | #2 |
91
Rep 610
foot in mouth, was thinking of 54c4 code. With that said i would still look at the t-case. when you say front wheels still spin, is that just up on the lift (ie no load)? how are you able to verify they have "power" (ie load)? it is possible that they are spinning as a result of friction in the fluid, but if you apply any load to the wheels they will not spin...
04-10-2017, 11:41 AM | #3 | |
106
Rep 808
04-10-2017, 03:44 PM | #4 | |
106
Rep 808
04-10-2017, 05:52 PM | #5 |
91
Rep 610
04-10-2017, 06:59 PM | #6 | |
106
Rep 808
04-11-2017, 10:20 AM | #7 | |
91
Rep 610
http://www.e90post.com/forums/showthread.php?t=1317462 What was wrong in those two cases was a needle BEARING basically disintegrated, causing the clutchpack to not be able to engage. A way you can check that (at least this is what my mechanic did when i brought it in) is to remove the actuator motor, and stick your finger inside the t-case to feel for the gear (the clutch gear that the actuator is supposed to engage). If the gear is there, can you spin it to a point where it is no longer going to contact the actuator? the cost of doing this check is the fluid since it will need to be drained. I would probably start with having the resistor coded to see if that helps. |
04-11-2017, 10:26 AM | #8 | |
106
Rep 808
04-11-2017, 03:24 PM | #9 |
91
Rep 610
no, i have never seen such a gear. i believe there is a value on the resistor that needs to be coded into the car. i did not do this myself, the shop to which i brought my car did (so they said), so my knowledge is limited to that.
05-06-2017, 08:02 PM | #10 | |
Rep 88
ever figure out the problem to this? |
05-07-2017, 11:01 PM | #11 | ||
106
Rep 808
