M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Regional Forums > USA - California
      04-04-2017, 04:07 PM   #1
chris @ eas
273
Drives: BMW
▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection.
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control unitscoding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your BMW is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Lighting
O Automatic High Beams (AHB)
O EU-Spec “Dazzle Headlights” (LED Adaptive lighting only)
O Enable Brake Force Display (BFD)
O Remove BulbCheck on Rear Turn Signals
O Amber Corner Delete
O Brighter Angel Eyes (50% brighter)
O Choose BFD Pulse Count (3/5 Flashes)
O Enable Taillight DRL
O Remove BulbCheck on Front Turn Signals
O Enable License Plate Lamps as Welcome Lamps
O Enable Fogs as Welcome Lamps
O Remove BulbCheck on Reverse Lamps
Exterior
O Close Windows with Comfort Access (CA)
O Fold Mirrors with Comfort Access (CA)
O Fold Mirrors with FOB (2-Step)
O Adjust Passenger Mirror Tilt in Reverse
O 1-Touch Window Up while Doors Open
O Pass mirror dips less when in reverse (decrease dip range)
O Fold Mirrors with door lock (AUTO)
O Windshield Wiper Return
O Disable Audible Chirp when locking
O Disable Auto-Locking of Doors once driving away
O Disable Headlight Washer Jets
O Disable Horn Honk when closing vehicle
O Disable Horn Honk Locking O Close Trunk with Interior Trunk Button
O Close Windows with FOB O Close Trunk with Key FOB
Interior
O Remove Seatbelt Chime/Reminder
O Auto Start/Stop (remembers last option)
O Always Remember Air Recirc. on startup
O Remove Speed Correction Factor
O Disable Active Sound
O Auto Start/Stop default to OFF
O Always Remember AC OFF on startup
O Start vehicle without brake pedal
O Digital Speedometer on BC Stalk
O Specify soft-touch blinker count (1-9)
O AC does not turn on when pressing AUTO
O Unlock door when engine is OFF
O Disable Welcome Sound (3 Gongs)
O Unlock all doors automatically upon vehicle shutdown
O Turn Signals in Heads Up Display (HUD)
O Enable Caller ID in Heads Up Display (HUD)
O Set Fuel Reserve warning to 7 Liter
O Enable Radio Station/Song Title in Heads Up Display (HUD)
O EfficientDynamics (shift indicator)
Navigation/iDrive
O Enhanced Bluetooth (6NS)
O Allow Top Camera View at all speeds
O DVDinMotion
O Enable USB Video/Movie file import (NBT)
O Bluetooth Pairing display at any speed
O Allow Side Camera View at all speeds
O Change NAV voice (British/US) (NBT)
O Enable Video playback from USB (NBT)
O Owner's Manual display at any speed
O Allow Side Camera View at user-defined speed
O Change DVD Region Code
O Enable Full Text in Office while Driving (NBT)
O Change iDrive startup animation (NBT)
O Disable Top Camera View at user-defined speed
O Add slider in iDrive for ambient light
O Turn off iDrive when door is opened
O Fuel Stop Sugg. in Route Guidance
O Disable iDrive Legal Disclaimer/Accept
O Disable Office Function Speed Lockout
O GPS Current Location to NAV menu
O Fuel Reserve Warning (9 liter to 6 liter)
O iDrive Map AutoZoom mode (NBT)
O Disable Rear Camera Legal Disclaimer
O Efficient Dynamics Mode (6MT only)
O Enable Speech Input for Email & SMS
O Add/Remove TPMS Tire Temp/Pressure Data
O Disable Side Camera Legal Disclaimer
O Enable Route Preview
O Navi Trip Import/Export
O Increase Maximum Message Count (max 50) (NBT)
O Disable FLIR Camera Legal Disclaimer
O Change BT ringtone to personal tone
O Create new Voice Email (NBT)
Phone:
You can reach us directly by calling 866.669.0705
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: chris@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
      04-06-2017, 06:38 PM   #2
chris @ eas
273
Drives: BMW
Coding slots available for immediate booking!
PM to get your car coded!
      04-07-2017, 06:15 PM   #3
chris @ eas
273
Drives: BMW
All PM's replied to!
PM today to schedule your coding appointment!
      04-10-2017, 05:33 PM   #4
chris @ eas
273
Drives: BMW
All PM's Replied to!
PM today to get your vehicle coded!
      04-14-2017, 06:07 PM   #5
chris @ eas
273
Drives: BMW
PM to book your coding appointment today!
      04-17-2017, 05:57 PM   #6
chris @ eas
273
Drives: BMW
PM to reserve your slot today!
      04-19-2017, 06:02 PM   #7
chris @ eas
273
Drives: BMW
Coding slots still available for immediate booking!
PM to book your appointment!
      04-24-2017, 06:21 PM   #8
chris @ eas
273
Drives: BMW
      05-02-2017, 02:05 PM   #9
chris @ eas
273
Drives: BMW
PM to get your car coded today!
Search this Thread:
Advanced Search
