335i to IS mufflers
03-26-2017, 08:47 AM | #1 |
1905
Rep 6,968
Drives: 2007 Black/Black 335i e90
335i to IS mufflers
Anyone doing a PE Performance Mod, 335is swap or PE swap on mufflers I would really and humbly suggest scoring the exhaust pipe with a exhaust pipe cutter and then using a sawzall with a diablo 18 tpi metal cutting blade. This is sooooo much easier than trying to cut through 1.5mm of stainless steel pipe. The sawzall blade curt through the SS pipe like a hot knife through butter (literally).
I speak from experience since I just swapped out my 335i mufflers for 335is mufflers. I am going to swap out the resonator for an x pipe soon. I have bought the red tail 2.5" x-pipe and 3 feet of stainless steel 2.5" 16 gage pipe, that is 304 grade SS. The red tail x pipe is also 304 SS too. Just gotta take both to an exhaust shop and have it installed. I am thinking the result should be as close to getting the PE exhaust as possible just short of buying the PE exhaust itself. I will have spent maybe $650.00 total vs $1,500.00... |
03-26-2017, 10:35 AM | #2 | |
537
Rep 2,825
if you have secondary cats, you can delete those for literally $100 and get just as good of a sound, zero drone, and a simple 3HP gain which i imagine is more then a 335is muffler. for $650 if you want real sound, you can the the PE mod to your stock muffler on top of the secondary delete and it will sound amazing. if you are looking for actual performance, downpipe and stock muffler is another great option. dont make it sound like your only choice is to spend $1500 replacing a catback that is already good out of the box, or spending $650 on an identical but slightly less restrictive muffler. |
03-26-2017, 12:35 PM | #3 | ||
1905
Rep 6,968
I am not interested in playing with cats or down pipes. I do not want to have to get a tune in order to drive around without blowing codes. The PE exhaust mufflers by themselves are about $750.00 used. The 335is mufflers are basically the same exact mufflers less minus the valve flap in the driver side muffler. I have never seen a 335is muffler cut open. I have seen a PE muffler and a 335i muffler open. There is absolutely a difference in the internals between both mufflers. My best guess is that the 335is mufflers are the PE mufflers less minus the valve flap and perhaps a different type of packing. The internal parts are probably the exact same. From an accounting stand point it makes no sense to create a third muffler using different internal parts. The manufacturer probably just takes a PE exhaust muffler and puts in different packing and slaps a different set of tail pipes on with the flap. That would be a lot more cost effective; it explains why both mufflers sound extremely similar. It also explains why the 335is mufflers are a tamer version because A they have a flap and B the packing is different. You can do the golf tee mod on the 335is mufflers to keep the valve open, in order to get closer to the sound of the PE exhaust mufflers. The x-pipe mod is the only other mod difference vs the coupe. I have viewed several videos of the PE Mod, 335is & PE exhaust mufflers. The 335is & PE exhaust mufflers sound the best; they are just more refined. |
03-27-2017, 11:00 AM | #4 | |
537
Rep 2,825
I do like the sound of the 335is alot.. I was talking about secondary cats. they do not have any o2 sensors, they do not mess with emissions whatsoever as long as you retain your primary cats, and your ECU will adjust to the mod perfectly within 4-500KM. I've done it myself so I can vouch for the sound and performance. I did it on my naturally aspirated 528i so I can only imagine how good it would sound if you already have a 335is muffler. there will be some crackles and burbling when you let off the throttle or downshift and the performance gains are great. honestly, for $100 I highly recommend you try it. you really got nothing to lose.. |
