03-25-2017, 11:20 PM | #1 |
140
Rep 625
Extremely LOW RPM Coasting?
Hello everyone,
So I just finished installing Jb4 to my 335... MODS: - Catless DP - BMS Intake - jb4 stage 2 - Resonator delete So when I'm coasting .... my rpms fall below 1000 at times before it downshifts into a lower gear..... I have done the gear adaption through the IACODER app a few times but it doesn't help.... Any ideas here..... it was fine before jb4 install.... I've tried updating jb4 to newest firmware no help.... removed it and still no help |
03-26-2017, 05:42 PM | #3 |
140
Rep 625
I tried with MAF enabled and disabled....
This happend after my tmap short post JB4 install Fixed that and still doing super low coasting!!! Like sometimes it downshifts at 800 rpm |
03-26-2017, 08:25 PM | #4 |
260
Rep 709
Probably won't be the issue but since it's simple and quick to do, have you tried reverting back to stock intake? I know open box gives idle issues sometimes, might be related to your issue as well?
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
03-26-2017, 08:37 PM | #5 |
559
Rep 1,127
did you try removing the BMS intake? That is the reason you have to disable the MAF in the first place.
FWIW I have the AFE magnum for a few years now, no issue with idle surge/maf. BMS and Injen intakes you will see a thread now and then with people stating issues they have experienced. |
03-27-2017, 02:37 AM | #6 |
140
Rep 625
Okay so I have a code now..... I just tried downshifting and punching it but it just surged like crazy and wouldn't go....
This is wkth JB4 active and Sensor unplugged P0100 - MAF CIRCUIT HIGH P0113 - Intake Air Temp Sensor |
03-27-2017, 01:23 PM | #7 |
260
Rep 709
Intake all the way, remove BMS, put on stock with a drop in K&N or Afe, and try again. Problems should be gone. Only thing you'll loose is spool noise, performance will feel the same for you
03-27-2017, 01:48 PM | #8 |
140
Rep 625
I am thinking that too but I've had this intake since I bought the car and it was fine at first..... throttle felt feather light and car launched right away
Now throttle feels heavy and car feels like it gained 1000 lbs..... I don't have stock airbox since I bought the car like that :/ Why would it throw those codes though :/ So when I installed jb4 I accidently put the ground wire to another positive power source ... with all the sensors connected... this So I fixed the TMAP ground but the car hasn't run the same ever since |
03-27-2017, 04:40 PM | #9 | |
260
Rep 709
03-29-2017, 04:23 PM | #10 |
21
Rep 94
This just started happening to me as well. I have MPPK intake box, catless dp and MPE with JB4 map 2. I thought it was just me but yea it gets around 1k or so coasting in comfy mode.
03-30-2017, 02:02 PM | #11 |
140
Rep 625
Yep and a jerky downshift cause rpms fall under 900....
I'm guessing one of my sensors are messed up at this point... it all happend after my older Jb4 shorter my TMAP and such |
