The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > DYNO-N55 PS2 through a 6AT/X-drive results!
      03-23-2017, 12:27 PM   #1
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Put the car on the rollers this morning finally.
Car is a 2011 X-drive 6AT with 100,800 miles on it.
96-97 octane blend in the tank. No E85.
PS2 turbo/Inlet/DV
VRSF IC
VRSF DP
VRSF CP
BMS Water/meth system running a CM12 @ 90/10 Meth/water. (Spraying a LOT of meth for about 10% added fueling)
Looks like I may have found the limit with the turbo on my particular setup. PWM maxed out at 99% from 5700rpm+ 26.5psi commanded.
Did 6 pulls between 18 and 26psi. Dyno numbers are SAE correction (For better accuracy). STD would show higher numbers.
I figure there's around a 50-60hp loss with the 6AT/AWD combination.
Here's the results and log (26psi)
http://www.datazap.me/u/cory-s/dyno-...-4-8&zoom=2-84
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
Appreciate 3
      03-23-2017, 01:30 PM   #2
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Nice. What plugs and gap are you running? Stock lpfp?
      03-23-2017, 01:34 PM   #3
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Stock pump yes. NGK 97506's @ .018"
      03-23-2017, 03:35 PM   #4
mwtrogus
Drives: 2014 X1 35i
Jb4 or MHD?
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom catless exhaust, KW V1, Volk's and everything else...!
      03-23-2017, 04:01 PM   #5
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Originally Posted by mwtrogus View Post
Jb4 or MHD?
JB4 + Cobb/BMS BEF
      03-23-2017, 05:20 PM   #6
weehe126
1161
Drives: 2017 340i
Interesting, that's about 30-40 whp less than I would expect. Even AT xdrive.
      03-23-2017, 05:31 PM   #7
bbnks2
1207
Drives: 135i N55
That's what happens when tuners post up there numbers std corrected lol I thought it was a bit low too though for what it is.
The peak looks to be on point to what pure advertises once you convert std to sae and account for AT/xdrive loss.
Cory S305.00
      03-23-2017, 06:20 PM   #8
Cory S
Cory S's Avatar
Drives: 2011 335i-X
We have a winner....
There isn't a higher N55 dyno number higher out there running a 6AT/X-drive
in SAE correction without PI/E85/stock LPFP combo.
      03-23-2017, 06:37 PM   #9
rich_mane
rich_mane's Avatar
139
Drives: 2011 E92 335i
500 ft/lbs of torque + xdrive.... That thing must be fun! Nice numbers.
Appreciate 2
Cory S305.00
      03-23-2017, 06:41 PM   #10
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Thanks. It's quite the daily grocery getter.
      03-23-2017, 08:02 PM   #11
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Very nice! I have the same drivetrain setup and it gives me a good idea what to expect. I will be adding the PS2 shortly. We need some vids!
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      03-23-2017, 08:12 PM   #12
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Ask and you shall receive
Appreciate 5
bbnks21206.50
JETmn245.00
rich_mane138.50
      03-24-2017, 06:49 AM   #13
ANMVQ
ANMVQ's Avatar
114
Drives: 2011 335XI Sedan
Nice numbers man, an that dyno reads LOW, been there before
2011 335XI
Cory S305.00
      03-24-2017, 08:14 AM   #14
JETmn
2011 335Xi  [0.00]
Now we need some on road/track videos to see how she moves out! Get xHP in that thing next week and it should be a screamer.
      03-24-2017, 12:56 PM   #15
WJMSprtXDrive
WJMSprtXDrive's Avatar
Drives: F15 xDrive50i M-Sport
Great info! Are you having any transfer case issues? Considering PS2 next year.
2011 E90 335i xDrive 6AT Performance Edition Package, M-Sport, TTFS Tune, VRSF 3.5" Catted DP, Active Autowerke CP, Turner Motorsport Strut Tower Brace, Hawk HP+, Bilstein B6, Alpina B3 TCU Flash, K&N ----
2014 F15 X5 xDrive50i M-Sport, RSE, 3rd Row
      03-24-2017, 02:34 PM   #16
Cory S
Cory S's Avatar
Drives: 2011 335i-X
You can't go wrong. No issues with driveline. Been on the car for 4000 miles now.
      03-24-2017, 06:05 PM   #17
WJMSprtXDrive
I see. Is it normal for the 1st to 2nd auto shift to be slower than 2nd to 3rd. Sometime it seems going from 1st to 2nd @ WOT the ZF 6HP does not snap off the shift. Maybe this is normal... Anyone else experiencing this?
      03-24-2017, 07:07 PM   #18
JETmn
2011 335Xi  [0.00]
Get the xHP flash (TCU flash) next week when it comes out. It shifts on the same level as the DCT.
      03-24-2017, 09:51 PM   #19
playground
Hong Kong
32
Drives: M3
What's the build date on your car if you dont mind me asking?
Become like water my friend.
      03-24-2017, 09:51 PM   #20
playground
Hong Kong
32
Drives: M3
Probably even faster to be honest. I'm looking at the shifts video, even my DCT doesn't shift like that.
      03-24-2017, 09:53 PM   #21
Cory S
Cory S's Avatar
Drives: 2011 335i-X
5/2010
      03-24-2017, 10:17 PM   #22
playground
Hong Kong
32
Drives: M3
5/2010
Nice engine.
Apparently from technical data and a tech from BMW.
Vehicles until 09/2010
I recommend due to susceptible pistons, connecting rods and VANOS no more than 360hp. The VANOS bowed in these models to destroy the engine to due to terminating pins. The piston and rod bearings are also quite weak, also BMW has recognized that.
Vehicles 09/2010 to 01/2011
Piston and the VANOS have been completely revised. The early troubles of the engine are eliminated. In a performance improvement I wouldn't worry much.
Vehicles 01/2011 to 03/2012
Build date from 01/2011 an approximately 3kg heavier and more stable engine block was introduced. This increased stability, improved smoothness and no longer known in older models idle fluctuations. Rod bearings has also been revised internally.
But your engine is already pushing 500WHP without any issues and that much mileage. I suspect its all about keeping the car well maintained.
