Catless DP, exhaust options for aggressive sound
03-16-2017, 12:47 PM | #1 |
hehe ty men
32
Rep 172
i have the PE mod done but it's a little too tame for my taste. I was thinking of getting the VRSF cat back but that seems pretty quiet as well. Does anyone have experience with muffler delete with catless DPs? The eisenmann sounds great but the price is pretty high
03-16-2017, 01:04 PM | #2 |
365
Rep 1,649
I originally did VRSF catless DP and straight pipes with small mufflers (vibrant) and it was loud. Droned sucked so I change it up to the catted DP they offer and Corsa. Still loud and zero drone. Muffler delete would do the trick though...
03-17-2017, 08:20 AM | #3 |
hehe ty men
32
Rep 172
Did it drone at every RPM? and are you talking about corsa resonators being added to the midpipe?
03-17-2017, 08:31 AM | #4 |
365
Rep 1,649
My previous custom exhaust droned like hell. He tried to weld on 2 resonators (vibrant) right before the mufflers to reduce drone but it only helped a little. I ended up selling the entire system and starting over. Now I have zero drone thanks to Corsa and the catted DP is still loud but no smell or any other issues. My tune is still "money" so it pulls hard as hell...370HP and 511 torque all to the wheels which is nice. Just changed the Transmission and Transfer case fluids yesterday and my tech did some sort of mechatronic calibration/adaptation to smooth things out. 3rd gear was out of wack a little.
03-17-2017, 12:15 PM | #5 | |
Boost Marauder
11
Rep 36
11' N55 335i xdrive - BMS Intake - VRSF Catback Exhaust - VRSF Catless Downpipes - JB4 Map 2 - Alpina TCU Flash
03-18-2017, 04:47 PM | #6 | |
hehe ty men
32
Rep 172
03-20-2017, 06:21 AM | #7 |
541
Rep 3,131
Drives: 2011 335i e92 DCT
Currently have catless downpipe, muffler delete and two resenators in the mid pipes.
Some drone around 2k rpm at low speed with your foot giving small acceleration. I think the ideal would be catless DP And a good catback. I had catless DP and the Actual Performance Exhaust and it was too loud. |
03-20-2017, 08:42 AM | #8 | |
157
Rep 772
Mods: MHD Stg 2, xHP Flashtool Stage 3, VRSF 3" Chargepipe, Megan 4" Downpipes, Pure N55 Inlet, Outlet, VSRF 5" Stepped Intercooler, GFB Diverter, BMS N55 Intake, Michelin Pilot Super Sport Tires, BMS Sport Oil Cooler Valve, CF Spoiler, CF Kidney Grille, CF Mirror Covers, CF Eyelids, CF Wheel Hub Covers, CF Diffuser, M Sport Racing Strip, 20% Tints, and Golf Tee Mod
03-20-2017, 09:14 AM | #9 |
30
Rep 130
I just put in a custom 3" exhaust from the DP back. No secondary cats, No muffler. Sounds beastly with the PPK. Drones at around a 1/4 throttle and around 2-3000rpms in 3rd. I plan on getting a catless DP once I get my JB4. I started out as loud as you can go and make it quiet from there. Going the other route seems more work to experiment around hence more money wasted.
03-20-2017, 01:11 PM | #10 |
Boost Marauder
11
Rep 36
It was ok with just stock cats, I had some complications installing it due to modifications to the pipe that meets the cats due to Xdrive, but other than that it was good. The VRSF catback plus the VRSF catless DPs is when you really get the full experience of the setup. If you want a deeper cruising tone and still the clean loud roar at WOT I suggest it. Best bang for your buck for a catback too
03-21-2017, 12:46 AM | #11 | |
541
Rep 3,131
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
03-21-2017, 10:12 AM | #12 |
30
Rep 130
03-21-2017, 07:56 PM | #13 | |
541
Rep 3,131
What you should consider is to get catless downpipes, this will give a decent performance increase but also make it very loud. Then get your shop to build you some resonators that can slide in where the secondary cats go. The resonators will quiet it back down to a good level. So you get more performance, similar sound (a tad louder), and a plug and play solution where you can swap cats and resonators in and out.
03-22-2017, 01:47 AM | #14 | |
30
Rep 130
gona correct myself on my previous post. the drone on my exhaust only happens a little over 1 - 2500rpms, after that its just a slight rumble. once i hit 60ish with consistent throttle, theres pretty much no drone |
03-22-2017, 02:37 AM | #15 |
45
Rep 158
Drives: White Buffalo
I have the PE mod as well as catless DP. The 4" DP i previously had sounded great but had bad welds.
Well....I began research on a few quality manufacturers I read about one being Wagner. Wagner DPs look a lot like the oem. Then I heard a voice..."hollow the oem dp and they will come..." Once I fired up the n55, immediatly was pleased with the sound. Throttle response much better and I can hear the spool as if I were in the turbo itself. Been rolling with that for the past week or so. I have noticed that Throttle may have a little more lag, as if the engine was heatsoaked. Oil temps definatly lower. I unplugged the exhaust flap this evening and was surprised once again. With the 5 or so inch dp and the flap open the response seems to be quicker and the vehicle now sounds like an angry, snarling, snorting, whistling and popping angry dragon. |
03-22-2017, 07:32 AM | #16 | |
541
Rep 3,131
I'll tell you how I go tomorrow, I'm having J pipes added, hopefully to eliminate the drone. I get the same drone around that RPM too |
03-22-2017, 09:25 AM | #17 | |
30
Rep 130
are you having the j-pipes where the stock mufflers use to be since thats the only open space the car seems to have lol. im assuming its going to look like a loop de loop right? back ->forward ->back |
03-22-2017, 05:26 PM | #18 | |
541
Rep 3,131
It will look something like the below, and yes, in the space the stock mufflers sit, right at the end just before the tips.
03-22-2017, 05:52 PM | #19 |
536
Rep 2,825
muffler delete with DP's is going to sound like shit.
your current PE mod with DP will be exactly what you are looking for. Im confused as to which e9x models have secondary cats and which dont, but if you have those you might want to delete them as well. |
03-22-2017, 08:06 PM | #20 | |
541
Rep 3,131
03-22-2017, 08:07 PM | #21 | |
541
Rep 3,131
N55 = RWD Cat in diwnpipe and nothing in mid pipes N55 = AWD Cat in downpipe and cats in midpipes
03-23-2017, 09:54 AM | #22 |
30
Rep 130
nice. my current setup has a pretty deeper tone. im assuming once i go catless they tone will refine to a more crisper sound like less bass more treble. and the ppk burple will sound like AKs which might be a tad too loud at that point lol. maybe if youve got time, up a vid with your new setup. curious what it sounds like with the jpipes.
