ISO-WTB Oil filter housing + OEM cooler
03-15-2017, 07:19 AM | #1 |
30
Rep 106
Looking to see if any of the "part-outs" or people with junk yard connections have this available.
I currently have a 2007 335xi without the oil cooler. I would like to retrofit one on, but know that I need both the lines, cooler, and updated OFH to connect the lines. If anyone can help me out with this, or point me in the right direction, I would appreciate it! Thanks. Last edited by milfriez; 03-15-2017 at 08:06 AM.. |
03-16-2017, 05:29 AM | #2 |
No 55mph
1622
Rep 8,476
Don't forget the cooler bracket/bolts, cooler duct, & the PS front inner fender liner for cooler option
I've seen all the parts available on ebay from time to time...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-16-2017, 06:57 AM | #3 | |
30
Rep 106
Uggg. Totally forgot about those. Guess it would be pointless to stick a cooler behind a sealed area with no airflow eh? I was looking at options yesterday, if I couldn't find OEM stuff, then to maybe go with the OEM OFH/Thermostat, then get those $70 adapter fittings and go braided SS to aftermarket. Still would need most of the above listed items though. What is the PS front inner fender liner? I was thinking power steering, but that's located on the opposite side of the car from the cooler? Last edited by milfriez; 03-16-2017 at 06:58 AM.. Reason: i suck at typing in the morning |
03-16-2017, 08:44 AM | #4 |
No 55mph
1622
Rep 8,476
PS = Passenger Side
There is a cutout with screw on grill in the front section inner fender panel on Passenger side that falls directly behind the oil cooler so that air flows thru front of cooler from duct and out thru the cutout/grill Otherwise the air flow would be deadheaded when it hits the cooler You need to go to realoem.com, plug in your car info & check out the appropriate exploded parts views to see everything you would need...
