03-15-2017, 05:48 AM | #1 |
281
Rep 1,017
Wheel offsets
Hi Guys,
Would anyone be able to let me know if the following would fit on our M2's? 9x19 ET 15 Front 10.5x19 ET25 Rear From what I can tell, they'd be almost like stock with 15mm spacers. Anyone know if they'll fit with stock suspension? Cheers |
03-30-2017, 12:09 AM | #4 | |
FOUO
415
Rep 873
(Someone correct me if I'm wrong). I have a set of ET22 wheels for my 1M, and I am 99% sure that it'll stick out on the rear |
04-13-2017, 10:16 AM | #5 |
158
Rep 478
I was just looking into this...
OEM wheel specs are as follows: 19x9 +29 F 19x10 +40 R I'd like to know the range of offsets we could put on the M2 so I can know what wheels to hunt for Thus far I've seen: BBS FI-Rs Front: 19x9.5 ET22 Rear: 19x10.5 ET35 Volk TE37s Front: 19x9.5 ET18 Rear: 19x10.5 ET22 *Super aggressive Signature Wheels suggests - Link Front: 19x9.5 ET30 Rear: 19x10.5 ET40 |
04-13-2017, 11:09 AM | #6 | |
BMW Newb
582
Rep 903
OrangeCrush1236.00 Seagull288.50 |
04-13-2017, 12:35 PM | #7 |
Dinosaur supervisor
3030
Rep 4,214
04-13-2017, 12:37 PM | #8 |
BMW Newb
582
Rep 903
04-13-2017, 10:55 PM | #10 |
1236
Rep 1,963
What tires are you going to be throwing on this setup?
Current
AW BMW M2 Past VO BMW 1M |
04-14-2017, 08:47 AM | #11 |
BMW Newb
582
Rep 903
Haven't decided yet, but either a set of oem F80 Pilot Super Sport take offs, or gong with a bit wider set of RE71r....
04-25-2017, 02:03 PM | #12 |
158
Rep 478
I feel like we should update the thread title to "M2 Wheel Offsets", sticky this and have people show what wheels and offsets they've been able to accomplish.
11-12-2018, 12:22 PM | #14 | |
565
Rep 1,092
They could still fit if you stretch the tires, add camber, the usual tricks. |
01-21-2019, 08:08 PM | #15 |
304
Rep 526
Need some help i have Vossen 20 inch wheels for my f80 m3 Front 20x9.5 et+21 and rear 20x11 et+34 will these fit M2 COMP looking to buy M2C ....want to see what i can use from my F80 and sell the rest... thanks so much .
Build by (PSI) 2019 M2C , BC suspension , BC wheels , DP , Vorsteiner trunk lip , Diffuser , Side Skirts , IND reflector kit , Rw carbón hood , DME Tuned !
E90 M3 Supercharged |
03-10-2019, 08:38 PM | #16 |
Rep 51
M2c - Wheel Offset - will these fit?
Looking to get in on an M2 and I have the following wheels from my M3. Wonder if they will fit...
Will 19 x 9.5 et +32 and 19 x 11 er +25 fit on and M2c? |
03-12-2019, 12:22 AM | #18 |
Rep 29
I'm no expert but I would say that it would be a squeeze, if not rub. And it would largely depend on what size tyres you plan to fit on as well.
Try using this basic calculator to get an idea. https://www.willtheyfit.com As an example, plug in the M2C rear stock rim size: 19x10 +40 with 265/35/19 Then put in your new wheels and tyres: 19x11 +25 Let's assume a new tyre size of 285/35/19 The calculator then states it would poke out 27.7mm at the rears. From what I've read, people are successful using 10mm spacers at the rear on stock rims without scrubbing.. so 27.7mm seems like it would push it. Last edited by pointy; 03-12-2019 at 12:56 AM.. |
03-12-2019, 12:45 PM | #19 |
24
Rep 81
03-17-2019, 11:23 AM | #20 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
03-17-2019, 01:45 PM | #21 | |
2428
Rep 2,526
Adding 15mm spacers to +19 offset nets you +4 offset. Given that stock is +29, theyre going to stick out 25mm (basically an inch) more than stock. |
04-01-2019, 03:10 AM | #22 | |
Rep 4
thx for this topic firstly i ask u this: M2 oem 19" are F: et29 R: et40 but they are et+29 or et-29 ???. this is my first question i think et+29 but this is very crucial to understand "rooms" in the car. Then second question is: i have found titan 7 ts5 for my M2 they are 18" 9,5j et22 for square setup with 255 semislick tires for trackday and i am not sure if they can work in my M2 my16 or i will have issues Some of you may help me? thx a lot |
