Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Regarding N55 stock exhaust & post cats.
      03-14-2017, 06:02 PM   #1
prima_materia
prima_materia's Avatar
58
Drives: 11' BMW 335i Sedan XDrive LCI
Quick question. I've seen on numerous threads where people mentioned having resonators and/or post cats on their N55 335i? I'm confused on this because while some claimed this, others claimed the opposite? Just confused, because when I installed my catless DP and looked over the exhaust I never noticed resonators/ post cats.
Also, in the Bentley manual under the exhaust section for the N55 I don't see anything in the descriptions or diagrams for resonators or post cats? I noticed post cats and resonators on the N51, N52, N52KP and N54 though.
Apologies if this has been covered, but like I said - both parties were claiming opposites, so that's mainly why I'm asking.
Even though I was under the car I can't remember, so that's partially why I'm asking also.
Cheers
JB4 ISO Map 7 @ 20psi, MHD/BMS e85 BEF, ISO_14 Firmware, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF Catless DP, VRSF 7in. FMIC,
      03-14-2017, 08:16 PM   #2
Kevin39
164
Drives: 2011 E90 N55
Hmm, I was under the impression that only the Rwd n55s didn't have secondary cats. Mine doesn't. But I thought the xdrives still did. Maybe someone else can chime in.
E90 N55 RWD 6MT MHD Speedtech EFR7670 MFactory LSD
      03-14-2017, 09:47 PM   #3
Redfire03
10
Drives: 2011 335I Xdrive M-Sport
Above is correct based on my understanding.
2wd = no secondary cats
AWD = secondary cats
I have an x drive and removed my secondary cats.
      03-15-2017, 03:16 AM   #4
prima_materia
58
Hmm, see this is odd, because I have an 11' xDrive and I don't think I have secondary cats. I have access to a garage, I'll get it on the lift here in a couple days, genuinely curious.
I could easily be wrong, but it's been bugging me lol.
      03-15-2017, 07:49 AM   #5
prima_materia
58
I stand corrected, looked under the car and it does indeed have post cats. :P
      03-15-2017, 07:02 PM   #6
STR8-6IX
536
Drives: RWD 528i N52
all e90's have secondary cats. my N52 equipped f10 has them (i removed them )
      03-15-2017, 07:09 PM   #7
ANMVQ
ANMVQ's Avatar
114
Drives: 2011 335XI Sedan
Does removing the sendanry cats do anything other then change tone? And emissions? Being MA I don't need any headaches
      03-15-2017, 11:24 PM   #8
DrRobert
Normal Person
Drives: 2011 E90 335i
2011 E90 335i  [0.00]
Not sure how the x-drives are configured, but I know that in my 2011 E90 335i the OEM downpipe contains two cats in series. In other words, I think the primary and secondary cats are both in the DP.
      03-16-2017, 03:24 AM   #9
prima_materia
58
Yeah, for my XDrive, right after the downpipe, not much farther after down the way there's two post cats.
      03-16-2017, 05:22 AM   #10
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
This is not true, N55 RWD does not have cats in the mid pipe
All N54 cars and N55 X Drive have mid pipe cats.
      03-16-2017, 06:32 AM   #11
Kevin39
164
^Yep.
Quoted text is incorrect.
      03-16-2017, 01:32 PM   #12
DrRobert
Normal Person
You are both correct. Like I said above, N55 RWD does have secondary cats, they are in the downpipe after the primary cat with an O2 sensor in between them.
      03-16-2017, 01:36 PM   #13
STR8-6IX
536
im confused here.. why didnt they all just get secondary cats after the o2 sensor? if anything, wouldnt the x drive version have secondaries inside the downpipe due to fitment issues with the xdrive?
however, I know that the f10 an f30 do not have secondaries (they are probably in the downpipe) but rather, a resonator and muffler. what is this for, cost cutting? better airflow?
my 2011 528i with the n52 has an exhaust system exactly like the e90 328i. I deleted my secondary cats and installed a magnaflow muffler. very happy with the sound.
      03-16-2017, 01:42 PM   #14
DrRobert
Normal Person
no idea. I just know this because I had both cats removed from my DP and had a HJS high flow cat retrofitted into it. There are definitely 2 cats in the 2011 E90 RWD DP (and the same DP is used for the 135i too). I have pics if you don't believe me.
      03-16-2017, 01:46 PM   #15
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
      03-16-2017, 01:54 PM   #16
DrRobert
Normal Person
Originally Posted by 9krpmrx8 View Post
Perfect. The hole in the middle of the stock DP on the left (just below the bracket) is for the O2 sensor. There is one cat in the top half and another in the bottom half inside the cylindrical part of the DP, on either side of the O2 sensor.
      03-16-2017, 02:22 PM   #17
DrRobert
Normal Person
OK, here is the DP from my 2011 335i:
Cat #1:
Cat #2:
      03-16-2017, 06:53 PM   #18
Kevin39
164
Here's the secondaries I'm talking about. Mine doesn't have that. I wouldnt consider the downpipe as two separate cats either.
      03-16-2017, 07:00 PM   #19
prima_materia
58
Yup ,that's exactly how my setup is for my 11' xDrive.
And yeah, when I think of the stock dp I don't think of it being '2 cats'.
      03-22-2017, 07:35 AM   #20
EB89
EB89's Avatar
Australia
541
Why would anyone think of the downpipe as two cats in a N55?
      03-22-2017, 08:03 AM   #21
DrRobert
Normal Person
Because it has two cats in it.
      03-22-2017, 08:03 AM   #22
prima_materia
58
Lol, exactly.
