'13 335i N55 tuning options
03-10-2017, 12:23 PM | #1 |
9
Rep 52
Hi, I have a 2013 335i e92 with the N55 engine. Car has around 28k miles and still covered under factory warranty (build date 05/13). I love the car but have been wanting to squeeze a bit more power out of it without having to install parts and such. I was looking over the forums and I saw many tuning options out there but have yet to see anything for late year e92s with updated DMEs. Is tuning possible on these cars? I'm not looking for high hp numbers (+400whp), just something quick and reliable. Maybe around 325-350whp? Thanks in advance.
03-10-2017, 12:57 PM | #2 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Bootmod3 is the only option I know of right now really. MHD will be out sometime in the future. JB4 is an option if you want to go that route.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
03-10-2017, 04:09 PM | #3 |
166
Rep 449
whether you are looking for "400+" or not you will never see that on these cars anyway unless you dump over $3k into a turbo upgrade and install, just wanted to clarify that. All tuning options out there right now for n55 will put you max at roughly 350 which would also necessitate supporting fueling or bolt-ons even though as JETmn stated, not many of these options are available for your DME yet (flash tunes that is). Your best option right now is a JB4.
03-10-2017, 06:17 PM | #4 | |
BimmerPost Supporting Vendor
24204
Rep 190,807
Boot Mod 3 is not compatible with E chassis, only F chassis. You can also get a Jb stage 1 or JB4
03-10-2017, 07:31 PM | #5 |
hehe ty men
32
Rep 172
Once MHD unlocks it for your car, I'd highly recommend getting MHD with a custom tune from Ken@WedgePerformance he's been doing a great job with my car and made it way faster + smoother. I went from JB4 to MHD with the OTS maps and now to Kens tune and This is the tune I'm sticking with
03-10-2017, 11:22 PM | #6 | |
166
Rep 1,700
can u compare jb4 to mhd ots plz ? |
03-11-2017, 11:50 AM | #7 |
hehe ty men
32
Rep 172
The jb4 wasn't very smooth, it FELT powerful because the boost came on all at once but the MHD was honestly probably just as quick but it felt much smoother. It was a bonus that I could use my p3 vent boost gauge with the MHD tune since it wasn't a piggy back tune. Once I flashed the first OTS map, I decided to sell my jb4.
But if you're running meth and stuff I think the jb4 + mhd backend flash is the best |
03-11-2017, 01:29 PM | #8 | |
166
Rep 1,700
you are totally right about jb4 only. the boost comes all at once and it feels fast but afr and trims are bad and its it wasnt very safe long term for my car i flashed the mhd backend flash few days ago and it feels a ton better its as quick like you say but power delivery is wayyy better smooth and linear but still damn fast if not faster i bought a meth kit so i guess ill stick to jb4 + mhd backend flash have you tried this combo ? im wondering if stage 2+ map mhd would be quicker than jb4 map 2 ? |
03-13-2017, 08:44 AM | #9 |
9
Rep 52
Thanks for your replies guys! Yes I know I will eventually need supporting mods (intake, downpipe, fuel upgrades, etc) to break a certain hp level but I would much rather stick to ecu tunes as this is currently my DD and I want to avoid modding to the point where it is no longer reliable. So it looks like I have two options at this point:
-Wait for MHD to unlock my DME -JB4 I've read both good and bad about the JB4 and honestly I don't like the idea of a piggyback system as I've had previous experience with one (not on a bimmer) and it turned out to do more harm than good. So I may just have to wait for MHD. Would you guys happen to know if the DME will need to be removed from the car for the unlock? Is it at all possible for these DMEs to be unlocked while on the car? Thanks |
03-13-2017, 10:39 AM | #10 |
76
Rep 290
I started with the JB Stage 1 tuner for my N55, but switched to MHD when it was released. I'd suggest waiting and going the MHD route. It has great power , smooth delivery and the tune options are really nice too.
03-13-2017, 01:47 PM | #11 |
245
Rep 1,595
My mistake, I forgot the coupe switched so much later than the sedan.
03-16-2017, 06:56 PM | #12 | |
58
Rep 165
By the way.. nice avatar cjd. I'm a big Alex Grey fan..
JB4 ISO Map 7 @ 20psi, MHD/BMS e85 BEF, ISO_14 Firmware, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF Catless DP, VRSF 7in. FMIC,
03-17-2017, 01:36 PM | #13 |
18
Rep 128
Little sucker MEVD1726
Like I said before, on a different thread, I think BMW locked down this DME to pull some extra Ca$h out of their PPK Flash, but WHY? my mistake is that I did not research enough before pulling the plug on my 13' 335i. I'm desperate too like the OP and wants MHD to unlock this sucker asap.
Power is Nothing Without Control!
03-30-2017, 07:31 PM | #14 | |
214
Rep 299
03-30-2017, 10:15 PM | #15 | ||
49
Rep 220
04-02-2017, 05:58 AM | #16 | |
365
Rep 1,649
04-02-2017, 05:59 PM | #17 | |
166
Rep 1,700
hes doing custom mhd flashes ? you have ewg ? 370 on 93 alone is good ! mind sharing a log sir ? |
Acidosis0.00 |
04-02-2017, 06:48 PM | #18 | |
365
Rep 1,649
To answer your question about MHD...not sure. Logs...not that into this stuff. I don't track my car so it's just a DD. Actually I'm bored and want something else. Tired of the DP noise and exhaust. Just want something normal and fast. Going back to a 550i I think...or wait until I find the right 2015 M3. |
04-02-2017, 07:19 PM | #19 | |
166
Rep 1,700
oh ok thx the info bud ! yea i know what you mean...sometimes a fast car stock straight outta the box is ideal but i found learning about the n55 motor and its tuning potential is very interesting...dont get me wrong i would get a porsche turbo s and call it a day if i had the money haha yea 511 is too much torque to floor it in 1st that for sure ! post a vid maybe |
04-03-2017, 10:29 AM | #20 |
79
Rep 247
I am in the same boat as the OP.
I went ahead and got the JB4 for my '13 after 3 weeks of having it. As soon as MHD finds a fix for our DME ill be flashing that and probably keep the jb4 as well. The JB4 does seem sort of jerky so would love to try out the MHD since i keep hearing that its smoother. |
04-03-2017, 06:32 PM | #21 |
33
Rep 129
What's the reason to run both JB4 *and* custom map? Seriously, that would seem to me to seriously complicate matters... Either let the JB4 do its thing, or let the custom map do its thing, but I can't imagine a scenario where I'd want two entirely separate controllers to manage air, fuel and timing at the same time! It's like having two people with their hands on the steering wheel driving the car!? Can someone provide enlightenment? |
04-03-2017, 06:55 PM | #22 | |
58
Rep 165
You're not supposed to run a standalone flash with JB4 though, as that could get rather wonky.
