SudduthCars | DINAN F series! (FREE SHIPPING) - AND....Special Start up promo!!! |
03-09-2017, 10:38 PM | #1 |
Rep 40
PM FOR QUOTES or QUESTIONS!!
DINANTRONICS Sport Performance Tuner for N20/N26 and N55 Engines (BMW ‘F’ Series) SPORT is not compatible with the 2010-11 F07 & F10 535i. DINANTRONICS Sport Maximum Gains (N20): Up to 30 HP, 50 lb-ft of torque. DINANTRONICS Sport Maximum Gains (N55): Up to 30 HP, 40 lb-ft of torque. Dinan Carbon Fiber Cold Air Intake for BMW F22 F23 M235i F30 335i F32 F33 F36 435i Benefits of the Dinan Carbon Fiber High Flow Air Intake for the F22 M235i, F30 335i and F32/36 435i: + More Power: +10 HP & +15 lb-ft of torque without additional modifications + Even more power can be achieved when combined with the DINANTRONICS Performance Tuner and exhaust. Consult the applicable DINANTRONICSproduct page for details. + Sportier Sound + Larger volume air box that completely seals + Optimized carbon fiber intake tube + Larger cylindrical air filter + Larger MAF + Quick and easy installation Dinan Free Flow Stainless Exhaust for BMW F32 435i Benefits of the Dinan Free Flow Stainless Exhaust for the F32 435i: + Uses the factory brackets and hangers for a factory-like fitment. + Helmholtz chamber to reduce drone. + Enjoyably louder, sportier Sound + 100% 304 stainless steel construction + Twin 89mm laser engraved ceramic black exhaust tips + 6 HP @ 6600 RPM, 5 FT-LB Dinan High Performance Dual Core Intercooler for BMW F22 M235i F30 F34 335i F32 F36 435i (N55) Benefits of the Dinan High Performance Dual Core Intercooler: + Max gains of 15 HP and 13 lb-ft of torque @ 6250 RPM (greater gains and a wider power band can be achieved when paired with stage 3 DINANTRONICS) + Face area 240% larger than the stock intercooler setup for maximum cooling efficiency to deter heat soak. + Charge Air Pressure drop: 0.80 PSI (25% improvement over stock) + Charge Air Temperature drop: 155º F (11% improvement over stock) + Charge Air Temperature / Ambient Temperature Delta: 18º F @ 6250 RPM (60% improvement over stock) |
