Tune which removes lag like the BMW PPK
03-08-2017, 11:23 PM | #1 |
109
Rep 1,062
Is there a tune that does this? PPK reduces spool time if your not familiar. Also is there a way to still get stage 3 PPK, I don't see it on BMWs website anymore.
Sideways is the way of life.
03-09-2017, 01:36 AM | #2 |
94
Rep 233
You're not going to find a lot of PPK talk here, there are much better options available than the PPKs. Short answer: yes there are off-the-shelf tunes available that will improve spool, power, torque, etc look up MHD. Dunno about the stage 3 PPK
03-09-2017, 01:42 AM | #3 |
596
Rep 1,693
PPK doesn't remove lag. It just has a little higher load target with the same throttle mapping which scales to the higher load target, making you think it has a little better throttle response. Tunes with more power than the PPK sometimes don't feel as responsive as PPK because of:
1) Throttle mapped to have a bit better control over your torque output. 2) More boost = slightly more time to make peak boost There is no magic added response in the PPK, just placebo from throttle mapping and not much boost. |
03-09-2017, 01:45 AM | #4 |
596
Rep 1,693
There is no "Stage 3 PPK". There is only one PPK power level. You can also get it with a cooling upgrade but the DME flash is the same.
03-10-2017, 06:15 PM | #5 |
BimmerPost Supporting Vendor
24322
Rep 191,063
Jb4
