Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Steering wheel loose
      03-08-2017, 03:57 PM   #1
TypeDre
Drives: F82 MW 6MT
Hi guys,
I've been dealing with an issue with my steering wheel/rack for awhile. This issue started as soon as I dropped the subframe to install downpipes on my 2008 335xi Coupe.
Basically the problem is my steering wheel is off centered and a few degrees off to the left when driving straight, however the steering wheel goes back to the centered position after I take a right turn, but as soon as I make a left turn or drive to the left the steering wheel goes off centered again. I originally thought it was my lower control arm bushing so I bought the control arm replacement kit from FCPEuro and have tie rods and both control arms replaced with no success. I've taken it to 3 alignment shops and all have told me that there is something loose with the steering rack? Or something with the steering.
My question is what part of the steering rack could be loose that we might have overlooked while dropping the subframe ?
Thanks in advance!
      03-09-2017, 10:14 AM   #2
Flyboy161
Flyboy161's Avatar
Drives: 2008 E93 M3
2008 BMW M3  [0.00]
2012 BMW E92 335i  [0.00]
So, you dropped the subframe and then the problem started. Go back ove the procedure to drop the subframe. Did you have to disconnect the steering wheel linkage near the rack and pinion?
      03-16-2017, 11:31 PM   #3
TypeDre
Drives: F82 MW 6MT
Fixed this issue today. It was the two steering rack bolts. Apparently they were loose and needed to be retightened
Tightened up the E12 bolt and now the steering wheel is heavier and feels alot tighter!
Flyboy161274.00
      03-20-2017, 11:00 AM   #4
F82Tazmanian
F82Tazmanian's Avatar
139
Drives: M8
Where exactly are the two bolts? I am having a loose steering issue, but was thinking steering shaft/u-joint replacement. Driving me nuts.
