03-08-2017, 01:39 PM | #1 |
241
Rep 307
Engine oil at minimum level with 3800 miles?
I got an alert saying my engine oil is at a minimum level and I need to add 1 qt within 125 miles.
I have 3800 miles on the car, is this normal? |
03-08-2017, 01:57 PM | #3 |
2925
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Do what @nvmaddog said and check in setting on a flat surface. If it still shows low, I'd bring to a service center because there has to be a leak somewhere.
03-08-2017, 03:35 PM | #5 |
45
Rep 46
When I first got my car it also burned some oil, I was at minimum before my first oil change. I babied it never went over 4000rpm. After that it always stayed at max oil level.
03-08-2017, 03:49 PM | #6 |
451
Rep 845
The N55 burns some oil -- more during break-in than later. I've had to top up two or three times I think. I had to put a quart in around 4000 miles, so don't worry too much about it.
03-08-2017, 04:48 PM | #7 |
5554
Rep 5,372
I had to add about .75 QTs over the first 5,000 miles. After that, the oil levels have remained very stable. I currently have 12K miles.
Like Liquidpaper pointed out, BMW turbo motors, just like most any other turbo motor out there, will burn some oil. The harder you drive and/or if you add power mods, you should expect to burn higher amounts of oil. It's entirely normal. All my prior cars, turbos or not, have burned some amount of oil. If you're burning a quart every 3K miles and it gets worse over time, then I'd start getting worried and ask for an oil consumption test. |
03-08-2017, 04:52 PM | #8 |
Rep 6
I was a quart low at about 4000 miles as well.
The dealer was close by and that is when I found out they would top off if it was a full quart low, gratis. |
03-08-2017, 05:32 PM | #9 |
1910
Rep 5,103
Same here. I burned through a couple of litres in the first 8k kms and none since. Check on a flat surface as suggested above
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
03-09-2017, 10:10 PM | #11 |
142
Rep 671
I think this is a break in issue. I've had many cars need a quart before their 1st oil change. But afterwards they were all fine.. Except this Toyota I've got.. Which did the opposite.. 1st 24K miles had no oil consumption.. afterwards.. it started eating oil.
03-10-2017, 12:05 PM | #12 |
235
Rep 421
just turned 19,000 miles on my 2016 228i RWD 6MT.
engine has never consumed a drop of oil....oil level checks always at 100%. Maybe an old wives tale...but I was very careful during break in (1500 miles) to "load the engine" while driving to "set the rings"...."no excessive idling", no revs over 4,000 unless by "mistake" I have to say...the engine/6MT is a "pleasure to drive"......smooth, powerful....I love getting onto an exit ramp lugging a bit in 3rd gear and feel and hear the engine rev flawlessly getting up to 80 mph before shifting into 6th gear....a dam blast ! |
03-10-2017, 12:05 PM | #13 |
682
Rep 1,017
My oil level was also close to the minimum needed before my first oil change. Last year before my HPDE, I stopped by the dealership and they gave me two quarts of 0W-20. They told me that as long as it was above the minimum to not worry about it, but gave me the oil anyway, in case I wanted or needed to add some oil.
I got a early message for service since it was a year from the manufacture date, although I hadn't had the car for a year, and only had 8500 miles on it at the time. The dealership changed the oil at that time, at my request. |
03-10-2017, 10:04 PM | #14 |
2865
Rep 3,842
Mine has never used a drop of oil since new. I broke it in driving through the mountains...Up through the gears and down through the gears. Decelerating is important, it helps to seat in the rings. Maybe the break-in had something do do with it, Maybe not.
03-10-2017, 10:31 PM | #15 |
235
Rep 421
same way for my cars breakin....always under load either accelerating of decelerating
03-10-2017, 10:32 PM | #16 | |
241
Rep 307
Thanks for the feedback guys. |
