Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > VMR 710FF on a pre lci e90
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      03-07-2017, 11:34 PM   #1
crystalline
29
Drives: 2008 335i
I'm looking for some opinions on the additional sizes VMR offers for the 19 inch VMR 710FF. I know the standard 19x8.5 ET35 front and 19x9.5 ET33 rear will fit without an issue. According to VMR they also offer a 19x10.5 ET45 (VMR didn't mention any additional offsets).
Can anyone confirm that the larger size will fit a pre lci sedan without modifications? From searching, it seems to be confirmed that you can fit a 19x10 (running a 275) on the pre lci e90 without modification...
I'm also interested to see if anyone has fit the 9.5 out front without modification, but the searches for that made it seem unlikely.
      03-13-2017, 08:56 PM   #2
crystalline
29
Drives: 2008 335i
No one has tried a 19x10.5 on stock pre lci sedan?
      03-16-2017, 09:48 AM   #3
BM3Rrrr
Davy Jones, Giant Squid
BM3Rrrr's Avatar
271
Drives: a Pirate Ship
I can for sure tell you 19x10 et 28 with 275/30 is ok on pre lci sedan.
Lowered. Slight rub over big dips
I think 19x10.5 et 45 would be fine with no spacers. Soon as you put a 10mm spacer and or wider tire then 275 you may rub.
      03-23-2017, 10:58 PM   #4
crystalline
29
Drives: 2008 335i
Thanks for the reply. It seems there are a few people running 19x10 275/30 or 35 even without an issue. 19x10.5 should really be 285 so I am slightly worried about the tire rubbing as well if I went with the bigger rear size.
Interested in any more opinions modded/unmodded on the wider widths. Got a few more days before I place my order.
      03-24-2017, 01:39 AM   #5
BM3Rrrr
BM3Rrrr's Avatar
271
Well et45 with a 10.5 rear should be ok as well. But if you want to add spacers be prepared to roll/shave.
Ohh and BTW I forgot to mention I run 19x9.5 et33 on the front with a 245/35/19 tire. Original offset was et45 but had to put a 12mm spacer on to clear the suspension. Other then that I have had no issues even when lowered.
