KW V1 what height to set it (# of threads from bottom)?
03-05-2017, 01:50 PM | #1 |
131
Rep 535
Any tried and true height setup (how many threads to leave on coilovers Front/Rear) for 162 style rims with 15mm/20mm spacers F/R so that it won't rub? I just don't want to go back and forth adjusting all 4 corners until I find proper height. Lot's of people have/had 162s and KW V1s - maybe someone can pinpoint correct height to begin with in the first place. Thanks
P.S. Staggered setup 225/40/18x8 F (+15mm spacer) and 255/35/18x8.5 R (+20mm spacer) on a e90 2007 328xi P.P.S. I'm thinking leaving 5-6 threads on front and set it in the middle on rear - that should give me around 1.5 inch drop F/R - is it about right? Last edited by n55jb4; 03-05-2017 at 01:56 PM.. |
03-05-2017, 03:59 PM | #2 |
3441
Rep 79,211
I have like 12 from the bottom on the front. 7 in the rear. It's a "2 finger gap".
5-6 threads is not that much, you will be pretty slammed. I'm not too keen on slamming an Xi, it puts a lot of strain on the CV joints and the car rides so much better just going up a little in my experience. |
03-05-2017, 04:54 PM | #3 | |
131
Rep 535
How much worse is ride comfort over stock xi? |
03-06-2017, 06:06 PM | #4 |
131
Rep 535
I checked threads of other people too and it appears there is no consensus on height. I can adjust fronts myself after install if I'll need to - it's DIY doable, but rears appear to be PITA - you basically have to take off control arm to fully adjust rears. So I really need to set rears correctly in the first place.
Jeff is saying his setup has 7 threads left from bottom in Rear to have 2 finger gap. I found photos where a guy has Rears set to max height and it's also 2 finger gap! Different fingers lol? Anyone else can chime in who had/has KW V1s on 328xi pre-lci? Thank you |
03-13-2017, 11:16 AM | #5 | ||
3441
Rep 79,211
Your best bet is just to get down and dirty and adjust the car. I was able to do the rears without taking them off. I just put vice grips on the Top Mount to keep it from moving. It was a bitch but less of a bitch then taking it all apart. |
n55jb4130.50 |
03-14-2017, 10:03 AM | #6 | |
166
Rep 1,700
have you done front sway bar on stock xi suspension ? if yes what does it do exactly and how did it feel ? thanks |
03-14-2017, 02:12 PM | #7 | |
3441
Rep 79,211
However, the FSB is the best mod for sure to date. Body roll is minimized. Much better front end grip, turn in ETC. A FSB upgrade even on stock suspension will be a good upgrade. I can understand not wanting to rebuild used KW's. Consider buying new, we offer them at a great price point right now during our tax refund sale. |
03-14-2017, 02:59 PM | #8 | |
166
Rep 1,700
