Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Alpina $ Ppk Competition??
      03-05-2017, 12:12 PM   #1
BKBMW335I
Drives: '11 E93 335I
THE FLASH FOR THE 335I IS HERE, I'M JUST UPDATING THIS TO SHOW IT'S AVAILABLE NOW!! (Caps purposely selected, not yelling)
xHP Flashtool
is the worldwide first and complete Tuning-Solution for your BMW with ZF6HP automatic transmission.
After 1.5 years of community driven development here on E90Post.com and some more 6 months and thousand of additional development hours, we are proud to announce the first all-in-one solution for BMW 6-speed automatic transmissions.
xHP Flashtool put's the power to fully customize your automatic transmission at your hands. Connect your Android smartphone to your car and customize around 100 maps by yourself or choose from pre-defined OTS maps in the xHP in-App Store.
Starting in February 2017 with support for 325d/330d/335d (E9x series) we will continuously work towards support of the whole BMW range. Next on the list are N54/N55 equipped E9x and E8x series cars, starting in March! The ZF6HP was BMW's automatic transmission of choice for their complete lineup for nearly a decade. From the 118d up to the mighty Alpina variants, BMW used these transmissions nearly everywhere.
Download on Play Store
App Main features:
Ability to flash your transmission controller (TCU) on your BMW with custom files.
The flash method is 100% safe. The TCU can always be restored to a working state, even if the cable get's pulled during a flash procedure.
Read/Delete TCU trouble codes (free)
Backup your TCU and restore to stock at any time you want
Choose from pre-defined maps in the xHP InApp-Store, or build your own files along with the community. From the day the app get's released you will be able to download a XDF file for user with TunerPro from our website.
Switch between maps in 4 minutes.
Pricing: 119 USD for the main flash license, which enables you to do as many custom flashes as you want. The OTS maps will range from 49 - 89 USD, depending on type and vehicle.
Required Hardware:
Android Device, running min. Android 4.1.2 (like Samsung Galaxy S2, 2011), USB-OTG compatible
USB OTG Adapter
OBD/INPA cable
OTS Map Features
OTS Maps will of course have different setups, depending on the vehicle, but in general they will share the following features:
Stage 1 Setup:
Optimized D Shiftpoints to facilitate sporty, yet economy style driving
Optimized Shift Strategy for up/downhill driving
Optimized Warmup Behaviour
Optimized Torque Converter Lockup in 1st/2nd/3rd gear
Lowered minimum RPM limit manual mode
Adapted Torque Limits for Tuned engines
Kickdown delete in Manual Mode
Start in 1st Gear in Manual Mode
Gear Display in Dash in D/S/M Modes
6HP21 TQ Limits: 413 ftlb (560 Nm), 6HP28 TQ Limits: 626 ftlb (850 Nm)
Stage 2 Setup:
Optimized D & S Shiftpoints for better acceleration in part and full throttle situations
25% faster, firmer, sportier upshifts in D/S/M mode
Faster paddle response time
Raised Torque Limits for Tuned engines
Kickdown delete in D & Manual Mode
6HP21 TQ Limits: 479 ftlb (650 Nm), 6HP28 TQ Limits: 737 ftlb (1000 Nm)
Stage 3 setup:
25% faster shifts in D mode
50% faster & very firm upshifts in S/M Mode
Instant paddle response time
Removed Rev - Limiters in M (True Manual Mode)
Race-like rev-match Downshifts (Throttle Blip) first time ever on Diesel BMWs
Lowered minimum RPM limit manual mode (5/6th gear)
Gear Display in Dash in D/S/M Modes"
6HP21 TQ Limits: removed, 6HP28 TQ Limits: removed
FAQ:
Q: Can I test xHP before buying anything?
A: Yes. The download of xHP is completely free. You can do a full read of your TCU and read/delete fault codes without any license.
Q: May I return to stock any time with xHP?
A: xHP creates a full backup before attempting any flash procedure. You can flash back your original file at any time.
Q: Do I have to connect my Android device with xHP to my car all the time?
A: No. You only need to connect, when you’re flashing, or reading data from your vehicle. During normal driving, you don’t have to have a live connection, or even carry the device with you.
Q: I’m going to sell my car. May I re-use my bought License on my next vehicle?
A: Yes. Just uninstall xHP before giving away your car. You can then connect your License with your next vehicle.
Q: How do I check if my vehicle is supported?
A: The best way is to download the xHP app and connect it to your vehicle. xHP will tell you instant if your vehicle is supported. Alternatively, you can head to www.rbttuning.com and check our vehicle list. We do our best to keep this list as correct and up-to-date as possible. However, BMW changed TCUs regularly during the production lifecycle and there may be cases where your vehicle is on the list but still not supported. These cases are rare, but cannot be avoided 100%.
Q: How about reliability, will I shorten the life of my transmission using xHP?
A: OTS Comfort and Sport setups won’t have any effect on the lifetime of transmission components. Not on the TCU, nor on the shafts or clutches. Keep in mind, that automatic transmissions are highly complicated units, with a few hundred components inside. Some of these components are designed to wear out (like clutches) through making use of them. Your driving style and proper maintenance have the biggest impact on the life-time of transmission components.
Q: Am I allowed to change between different OTS and custom tunes?
A: You can switch between tunes as often as you like and you are allowed to buy multiple OTS tunes and manage them on the same device.
Q: Am I able to log data with xHP?
A: We're working on an additional logger module, which will be released during 2017.
Q: I'm running an Alpina flash currently, do i have to revert to stock before using xHP?
A: No. xHP saves the Alpina flash as backup and then overwrites it.
Q: Is my car supported right now?
A: Please look at our supported vehicles list on www.rbttuning.com. This list will grow over time.
Q: How about N54/N55?
A: xHP will support 135i/335i beginning during March. Generally all build dates > 03/2007 will be supported from March on. Pre 03/2007 cars may follow later.
If you have additional questions, feel free to ask here directly, shoot us a PM, contact us through our Website or follow us on Facebook!
Mods: MHD Stg 2, xHP Flashtool Stage 3, VRSF 3" Chargepipe, Megan 4" Downpipes, Pure N55 Inlet, Outlet, VSRF 5" Stepped Intercooler, GFB Diverter, BMS N55 Intake, Michelin Pilot Super Sport Tires, BMS Sport Oil Cooler Valve, CF Spoiler, CF Kidney Grille, CF Mirror Covers, CF Eyelids, CF Wheel Hub Covers, CF Diffuser, M Sport Racing Strip, 20% Tints, and Golf Tee Mod
Last edited by BKBMW335I; 04-19-2017 at 12:41 PM.. Reason: I just thought we needed this on our forum too, this should be a STICKY!!
sd306380.50
      03-06-2017, 08:48 AM   #2
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Not competition at all, xHP will blow away the Alpina flash. A whole different ball game. This is like comparing ppk to MHD...
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
BKBMW335I156.50
      03-06-2017, 10:20 AM   #3
Johnny Boost
324
Drives: '21 M850i GC
This looks very promising. Looking at the app, it appears they only support diesel models.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
BKBMW335I156.50
      03-06-2017, 10:57 AM   #4
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Well, the Alpina flash is free, so it's got that going for it
BKBMW335I156.50
      03-06-2017, 12:01 PM   #5
CanadianTSi
CanadianTSi's Avatar
207
Drives: 2014 535 xDrive Diesel
http://www.e90post.com/forums/showth...&highlight=Xhp
Appreciate 2
      03-06-2017, 12:05 PM   #6
JLGM4
57
Drives: 2016 M4
Does this mean that the stage 3 version of the app will finally cancel out the auto-upshift at redline? That's what I want more than anything
Appreciate 2
      03-06-2017, 12:17 PM   #7
JETmn
2011 335Xi  [0.00]
N54/N55 6AT support is coming later this month. The diesel support just came out last month. They actually just put a test N54/N55 update out for a day to get it to testers. I wish I would have saw it, I would have jumped on it.
BKBMW335I156.50
      03-06-2017, 01:27 PM   #8
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
Interesting. Any plans for DCT support?
BKBMW335I156.50
      03-06-2017, 05:52 PM   #9
prima_materia
prima_materia's Avatar
58
Drives: 11' BMW 335i Sedan XDrive LCI
I had no idea about xHP until this thread. This is awesome.
I really wonder how similar/different this will be from Alpina, it terms of overall driving experience? I was still planning on going Alpina, but who knows. I'll see where this goes in the coming month/s.
JB4 ISO Map 7 @ 20psi, MHD/BMS e85 BEF, ISO_14 Firmware, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF Catless DP, VRSF 7in. FMIC,
BKBMW335I156.50
      03-06-2017, 09:44 PM   #10
Johnny Boost
324
It should actually be better than Alpina since you have more options for customization. I have seen a lot of people complain about the D mode with the Alpina. Now you'll be able to tweak D/DS/M how you want them.
Appreciate 2
      03-07-2017, 03:36 AM   #11
prima_materia
58
Nice man. Yeah I watched the youtube video, and how there's various stages to the flashes, which I'm curious as to how different each one is, and how they'll stack up against Alpina. Suppose I should dig in the xHP thread a bit more, haven't really read through it yet.
That's pretty awesome though - what you describe - the tweaks to D/DS/M. And yeah, I read in several threads about people complaining about D with Alpina, thankfully I never drive in D lol. M ..like 98% of the time. Mainly what I'm after is the quicker shifts between gears and the rev matching, this stock TCU flash and AT shifting isn't cuttin it.
I love how even after all these years, things like this are still being developed for the N55. Good stuff.
BKBMW335I156.50
      03-07-2017, 09:16 AM   #12
JETmn
2011 335Xi  [0.00]
Read the first post of the xHP thread. It goes over the stages pretty well. Stage 3 is going to be where it is at. D mode superior to stock or Alpina and sport and manual modes drastically better than either. There is a video of a guy with a diesel that shifts like a dct. I can only think the 335i will be even faster.
Appreciate 3
      03-07-2017, 05:34 PM   #13
prima_materia
58
Yeah, would've helped if I just scrolled up to the top of this page and read things more carefully lol. Yeah that stage 3 setup looks like the ticket.
Im ready.
BKBMW335I156.50
      03-07-2017, 10:49 PM   #14
Redfire03
10
Drives: 2011 335I Xdrive M-Sport
Can't wait for n55 support!
BKBMW335I156.50
      03-09-2017, 06:42 PM   #15
JLGM4
57
Drives: 2016 M4
Still curious as to whether this will disable the auto upshift in manual mode when you hit redline. I'd like to be able to bounce off and spin the tires a little rather than it taking me straight into second
BKBMW335I156.50
      03-09-2017, 07:00 PM   #16
Kevin39
164
Drives: 2011 E90 N55
From the diesel videos I saw on YouTube, yes it will stop the auto upshift
BKBMW335I156.50
      03-09-2017, 07:55 PM   #17
CanadianTSi
207
Appreciate 4
      03-10-2017, 07:41 AM   #18
JETmn
2011 335Xi  [0.00]
Holy crap that is fast!! I will be ordering it as soon as it comes out!
BKBMW335I156.50
      03-10-2017, 09:26 AM   #19
D.I.P.
D.I.P.'s Avatar
Drives: 11' 335i xDrive
Woah... looks like ill be replacing my Alpina Flash with this the day it becomes available for the N55... Those do look like DCT type instant shifts
08 135i Coupe 6sp ///M Sport - on jackstands
11 335i X-Drive Sedan 6AT ///M Sport - SOLD - PPK - xHP Flash - MHD Stage 2+ - VRSF 3.5" DP - VRSF CP - VRSF 5" FMIC - AA GREEN FILTER
09 135i Coupe 6sp ///M Sport - SOLD
- SSK - RL DP's - JB4 - BMS DCI
BKBMW335I156.50
      03-10-2017, 09:37 AM   #20
prima_materia
58
Yeah, that looks great!
BKBMW335I156.50
      03-10-2017, 12:31 PM   #21
YasF80_SLO
YasF80_SLO's Avatar
Drives: F80
2015 BMW M3  [0.00]
2018 Nissan Versa S  [0.00]
WOW! I really want this on my n55 now haha, looks killer in comparison to alpina
BKBMW335I156.50
      03-10-2017, 08:44 PM   #22
Welcome to NBA Jam
Is it the shoes!?
3884
It almost makes me regret getting a manual. almost
Appreciate 3
