03-04-2017, 07:42 PM | #1 |
Amateur Tattoo Artist
809
Rep 700
So here is what I've learned so far
Big thanks to Mike at Extreme and the guys at BMS for answering all of my questions.
I was hoping to go simple on my M2. I paid for an extended factory warranty. And while my dealership is pretty cool with mods, I still wanted to keep it low key. I have a bad habit of tuning my cars as soon as I get them. I wanted to avoid an entire piggy back system like the JB4 just for simplicity sake. Thought I'd go JB+ for a few more easy ponies. All the smart people I talked to advised against this for safety reasons. Said if you're gonna do it, just get the JB4. Less risk. So I guess I'll wait till I get bored and then go JB4 So for now, think Ill put on my BMS intake, BMS can flap module and a full Dinan exhaust. So basically sound mods My dealership doesn't do Dinan mods. Found a dealership about 50 miles north that does. Said to order it through them, takes about a week. Then schedule an appointment for install. Seems pretty simple. Anyone go this route with a BMW dealership? Also thinking about eventually doing a sports cat. My dealership says they're fine with mods, but did give me a warning. Said that they'll be happy to replace anything, but when BMW sees big repairs like engines, turbos, etc, they start to ask questions and want to interrogate the computer stuff themselves Ill see how long I can hold out |
03-05-2017, 07:34 AM | #4 | |
1913
Rep 2,210
Drives: '17 jackrabbit on crystal meth
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
03-05-2017, 10:10 AM | #5 |
1577
Rep 3,888
It seems that you'd want the JB4 when modding fueling, DP, or turbo. But for otherwise stock, including any other intake or exhaust mods, the JB+ would have less risk simply because the reliable factory tune with its safety features is being used.
03-05-2017, 11:39 AM | #6 | |
809
Rep 700
Apparently not in this case. |
03-05-2017, 12:02 PM | #7 | |
1577
Rep 3,888
The BMW DME should still be reading correct duty cycle, A/F ratio, IAT, knock, throttle position, etc. - basically everything required to limit boost to conform to operating parameters. With everything being monitored for safety margins, if there are no codes, then safety should be maintained. The factory turbo can run as high as 19psi to compensate for low air density. Theoretically, with the JB+ the car should be behaving as if there was less air such as when at a higher elevation. For fueling, the O2 sensor should compensate for the increased air flow. |
03-05-2017, 12:51 PM | #8 | |
809
Rep 700
03-05-2017, 01:34 PM | #9 |
133
Rep 229
Dinan website:
DINANTRONICS Sport module installs on the boost sensor and not the manifold pressure sensor, ignition timing and air-fuel mixtures remain safe for worry free driving. Full disclosure: I know nothing about engine safety.
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
03-05-2017, 02:13 PM | #10 |
1577
Rep 3,888
If that's what it says, they are wrong.
