03-04-2017, 04:03 AM | #2 |
3179
Rep 2,577
One of my m2 friends is using Eisenmann. We believe he's been the first and only F87 Eisenmann user to date in China.
It doesn't change much how stock system sounds but instead amplifies it, which is good because stock low end grunt is really sweet. We compare different F87 sounding system all the time - MPE, akrapovic, IPE, FI, Eisenmann and I believe my impression is very accurate. I can upload a sound clip of my friend's Eisenmann when I get to the computer. Now the downside: The Eisenmann system is built in multiple pieces, connected by clamps. But the fitment wasn't perfect. Mechanic did a lot of adjusting and used sealant to ensure no leakage from between downpipe and midpipe.
Lemania 2320
reddemon27.50 |
03-04-2017, 11:59 AM | #3 | |
45
Rep 148
03-05-2017, 09:59 PM | #4 | |
3179
Rep 2,577
That being said, a high flow or decat downpipe will be more effective in achieving desired loudness.
Lemania 2320
reddemon27.50 |
03-06-2017, 12:41 AM | #5 | |
28
Rep 51
could you further enlighten me with some answers. 1)for akra if i install the soundkit, can i permanently leave the valve open?so that when i next start the car again, the valves will STILL be opened. 2)eisenmann afaik, doesnt come with a switch to open the valves right?so, it will just bang on the stock valve controlling system and it will open the valves on high load? i like mpe.unfortunately, i heard there's a bad rattling on cold start and they are revising it.also, in my country of residence, i could not get a mpe from my agent.(was just told they dont ship it here). armytrix and fab are out of my options as i cant find any distributor here and they are definitely illegal in the eyes of the law. |
03-06-2017, 09:57 AM | #6 |
3179
Rep 2,577
Akrapovic remote controller always has valve closed as default when engine starts. Eisenmann is simpler just following stock valve behavior.
Lemania 2320
03-06-2017, 02:01 PM | #7 | |
336
Rep 522
03-06-2017, 08:20 PM | #8 |
3179
Rep 2,577
Make no mistake, FI hasn't been quiet historically. But its F87 system has a similar design to stock system. They have tricks made in the muffler, rather than partially bypass it. To me, it's sounding very good at down low and mid range IRL, but a little bit too raspy up top. MPE & FI, when both with valves open, are close in term of loudness.
BTW, FI has the largest tip diameter I've seen for F87. From all I've heard, it looks like an easier job to make a good sounding F87 system than a bad one
Lemania 2320
