Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > What Motor Oil and grade do you have in your 335i?
      02-27-2017, 06:17 PM   #1
flexinator
flexinator's Avatar
Drives: 2011 335xi coupe
2008 335xi  [0.00]
I wanted to get an idea of what people are using in their tuned cars. Please list Motor Oil type, Grade/Thickness, how often you change it, and how satisfied you are with the oil and oil analysis if available.
I use:
Castrol, German type LL-01
0w-30 soon to be 0w-40
changed every 3-5k miles with Mann or K&N oil filter
The car runs great, smooth, oil analysis soon
      02-27-2017, 06:28 PM   #2
cjdzombie
cjdzombie's Avatar
Drives: 2011 E92 335i xDrive, M Sport
Castrol 0w-40 every 5000. Its all Ive used so far. Seem to get the job done.
Appreciate 2
feuer4275.50
      02-27-2017, 06:40 PM   #3
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
BMW 5w30 every 12-15k miles.
I'm going to get Pentosin 5w30 next change since it's about $15-20 cheaper than the dealer.
      02-27-2017, 08:18 PM   #4
CantCatchMe
Romania
340
Drives: 2012 335i xdrive msport(E92)
Liqui Moly 5w40. I change it every 5-6.5k miles. I've noticed some slight improvements compared to the BMW(Shell) oil. I will be sending a sample of my oil to Blackstone. I've noticed my car is a lot quieter at cold start now.
VRSF 7" IC, VRSF CP, aFe panel filter, VRSF DP, Pure Inlet Pipe, MHD/Twisted Tuned, Performance Exhaust, Koni Yellows on Eibach Pro Kit springs, Turner adjustable front endlinks, R1 Concepts Slotted Rotors w/ Hawk 5.0 pads, VMR's 710, Fuel It Stage 2 LPFP, 3.5 TMAP, CYBA 3.8" black chrome exhaust tips, Orange Vinyl Wrap, CF bits, coding, Pure Stage 2 turbo w/ DV+(NGK plugs), xHP trans flash, and more.
STR8-6IX536.00
      02-27-2017, 08:41 PM   #5
bbnks2
1207
Drives: 135i N55
Castrol edge euro 0-30 would be my choice but it's hard to find. I use the 0-40 because that's what's available on the shelf.
Change it every 5k. I have a sample waiting to go out to blackstone now actually... They are recommending trying 7500 miles as of my last sample. First I sent them a 2500 then a 5000 sample. Less than avg metal counts and above average life left on the oil even after putting track days on it... hard to argue against it since it's by far the cheapest and most available!
feuer4275.50
      02-27-2017, 10:20 PM   #6
feuer
feuer's Avatar
Drives: wife crazy!
12-15k OCI and trying to save $15-20 on the oil. I honestly don't understand the line of thought. For that OCI you should get the best oil and Pentosin is certainly not. Isn't that you had it coming too but Rotella T6 would be a better choice.
Appreciate 2
sy2767144.50
STR8-6IX536.00
      02-27-2017, 10:25 PM   #7
feuer
feuer's Avatar
Drives: wife crazy!
Change every 5k. I have a sample waiting to go out to blackstone now actually... They are recommending trying 7500 miles as of my last sample. First I sent them a 2500 then a 5000 sample. Less than avg metal counts and above average life left on the oil even after putting track days on it... hard to argue against it since it's by far the cheapest and most available!
My Rotella T6 0w-40 supply is about to end. I have probably enough left for 2 oil changes. Castrol Edge Euro Formula 0w-40 is $23 for 5L vs $21 for 4L Rotella T6 so I will be making the switch I guess. After 6 years.
bbnks21206.50
      02-27-2017, 10:58 PM   #8
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Motul xcess 8100 5w40. UOA can be found here.
http://www.1addicts.com/forums/showthread.php?t=1193418
STR8-6IX536.00
      02-28-2017, 12:32 AM   #9
Welcome to NBA Jam
Is it the shoes!?
3884
Originally Posted by feuer View Post
12-15k OCI and trying to save $15-20 on the oil. I honestly don't understand the line of thought. For that OCI you should get the best oil and Pentosin is certainly not. Isn't that you had it coming too but Rotella T6 would be a better.
Pentosin specifically manufactures oil for that OCI. Rotella T6 is a low SAPs oil designed for diesels.
The thought process? I don't perform more maintenance on basic items than I need to; simple as that. There's an algorithm in the car that calculates how long the OCI is based upon fuel usage and a direct measurement of oil quality through electrical conductivity. That's what I follow for oil changes.
      02-28-2017, 07:34 AM   #10
feuer
feuer's Avatar
Drives: wife crazy!
You completely missed my point.
STR8-6IX536.00
      02-28-2017, 12:17 PM   #11
bahn
Drives: 2007 E92 335i 6MT
4,000 Mile OCI on BMW 5W-30 FWIW
feuer4275.50
      02-28-2017, 08:24 PM   #12
flexinator
flexinator's Avatar
2008 335xi  [0.00]
Nice report. Has anyone used redline in the 335i?
      03-03-2017, 11:27 PM   #13
LeYoshi
LeYoshi's Avatar
15
Drives: 2011 BMW 335i E92
Liqui Moly 5w-40!
STR8-6IX536.00
      03-03-2017, 11:39 PM   #14
#Tee
#Tee's Avatar
557
Drives: yes
castrol synthetic 10w/30
You can follow my builds on IG: Tee212
      03-04-2017, 01:48 AM   #15
feuer
feuer's Avatar
Drives: wife crazy!
Any particular reason 10w-30 ?
      03-04-2017, 02:37 AM   #16
#Tee
#Tee's Avatar
557
Drives: yes
actually no? i live in socal and used 10/30 on every car ive owned and family members as well. some turbos and mostly na. switched to 15-40 and 20/50 on higher mileaged engines and never had any oil starvation or performance related issues. with automotive i normally stick to what works and try my best not to try new brands or repair procedures cause we try not to repair it again and again. but thats never the case with me lol
feuer4275.50
      03-05-2017, 06:58 AM   #17
AirbusPilot
AirbusPilot's Avatar
34
Drives: 2023 M550i
Amsoil 5w40 euro.
Probably switching to M1 euro next time. I read they changed the formula and the results were great. Since it's cheaper, and I can find it locally, why not.
STR8-6IX536.00
      03-05-2017, 08:15 AM   #18
flexinator
flexinator's Avatar
2008 335xi  [0.00]
They changed the formula, the PDS numbers look great but it's no longer BMW long life one approved. It's not clear why it's no longer approved but from the used oil analysis on Bob is the oil guy my guess is it does not Retain grade and breaks down too soon under high shear. It's viscosity index and HTHS are excellent. It was the last mobil that was a long life approved and I would use it but without that certification I'm not going to take the risk. How does the Amsoil 05W 40 run?
      03-05-2017, 08:30 AM   #19
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Originally Posted by AirbusPilot View Post
Amsoil 5w40 euro.
You have uoa on the amsoil?
      03-05-2017, 03:10 PM   #20
AirbusPilot
34
Drives: 2023 M550i
Not for the BMW, but several uoa's I had from my Z06 looked fantastic.
      03-05-2017, 03:14 PM   #21
AirbusPilot
34
Drives: 2023 M550i
All I can tell you is the oil temp runs about 5 degrees cooler. I change it at about every 6k miles. Did not know that about the M1 new formula, just read a comparison test where it out performed the old formula.
      03-05-2017, 04:03 PM   #22
flexinator
flexinator's Avatar
2008 335xi  [0.00]
Mobil 0w-40 lost the GT-R and LL01 approval
http://www.e90post.com/forums/showthread.php?t=1230085
http://www.gtrlife.com/forums/topic/...pecifications/
Tags
change interval, grade, motor oil, oil filter, thickness. change oil
