Port Injection with Stage 2 LPFP?
02-26-2017, 04:46 PM | #1 |
11
Rep 91
anybody have experience and dyno numbers for running port injection with just the fuel-it stage 2 LPFP?
Should've went with stage 3 from the start but i never thought I'd upgrade twins and now wishing I had. My goal is 650whp on e50 tune at roughly 25psi, definitely not looking 700+ or to break any records. |
02-26-2017, 05:10 PM | #3 | |
11
Rep 91
And by the way, I have his MMP stage 3 with just stage 2 LPFP with e50 tune at 22.5 PSI and cant get those dyno number's he's claiming, by far. Turbos are fine, it's fueling thats the limiting factor. Quite disappointed. Hence I'm here now hoping people would chime in on their S2 and PI. |
Bimmer 808170.00 |
02-26-2017, 07:48 PM | #4 |
109
Rep 235
Ugh, i hate the whole stages BS. It's like being on a Honda forum again. Wtf is a stage two lpfp?
Anyway one walbro flows enough for 500 whp under the right conditions. Two running together should get you there plus some. |
02-27-2017, 10:37 AM | #5 |
48
Rep 161
I can't say I've ran across anyone with PI and stage 2 personally. Have you asked Steve if he knows of anybody? What numbers are you pulling with your current setup?
2008 335I 6MT
Tune by Wedge Performance |
02-27-2017, 12:08 PM | #7 | |
11
Rep 91
I bought the MMP S3 with just stage 2 LPFP in hoping to make 630whp since that was what is advertised on the website. I dyno'd at 532whp on e50 at 22.5 PSI so as you can see I'm way below goal so quite disappointed. At time of install I had new plugs, coils. Log showed no timing pull so octane was great. LPFP was averaging around 65-75 psi. HPFP around 1200-1400 psi, and once in a while would dip to 1050. Misfire would occur at top of 4th on back to back pulls. At time of dyno I think I had e60 since I wanted to make sure octane wasn't going to ruin the runs, which equates to 2 extra gallon of e85 in the 16 gallon tank, but considering S2 LPFP can run 100% E85 i dont think that was a factor. |
02-27-2017, 02:00 PM | #10 |
72
Rep 116
02-27-2017, 06:02 PM | #11 |
31
Rep 105
Seems like there is no way to get >550whp with any meaningful mix of ethanol without HPFP crashing. From what you are saying, the LPFP probably isnt the limitation. 1000psi on the HPFP sounds more like the problem. Adding PI reduces strain on the HPFP by not requiring DI to work as hard.
If you read Steve@FuelIt's posts around, there is no way people are making that power without PI. Maybe on 100+ unleaded gas. Since this site blocks linking to other relevant forums, here is the snippet. Q: I'd like to run ethanol (E85) what upgrades do I need? To run moderate to high concentrations of ethanol you'll need a Stage 2 or Stage 3 LPFP depending on your power goals. Stage 2 will be needed for up to approx. 550whp and Stage 3 will be needed for 550whp+ A healthy stock HPFP on an E-Series can support up to approx. 430whp on E85 and approx. 460whp on E50ish. |
02-27-2017, 06:43 PM | #12 | |
60
Rep 80
02-27-2017, 07:38 PM | #14 | |
60
Rep 80
02-28-2017, 02:17 AM | #15 | |
11
Rep 91
My tuner and I dont understand how he can get such a high #. 2-3 other people with my exact same setup are getting 510-535 so I'm not the only one with this result. And theres definitely 2-3 people who were first adopters of pure stage 2 that had just stage 2 lpfp and 100% meth making 680-700whp, dyno verified. Their engines finally blew at some point. There's absolute no way I'm running meth, and to be honest due to safety mechanisms not fully mapped out for PI directly from the DME, I'm kinda hesitant to run PI also. |
02-28-2017, 08:59 AM | #16 | |
31
Rep 105
02-28-2017, 12:23 PM | #17 |
Rep 32
02-28-2017, 12:26 PM | #18 |
202
Rep 649
I was able to do 100% E85 on my old single turbo car, 6466 on 20 psi. The LPFP pressure was dipping a little bit but the HPFP was holding strong and so were AFR so no problems there. Car rolled out. Our E85 here is like E90 too.
17 M3 Comp
02-28-2017, 03:11 PM | #19 |
659
Rep 1,525
10-27-2017, 12:50 PM | #20 |
119
Rep 1,525
Well pretty old thread but I have a friend running a stage2 (not fuelit) at 26psi with PI and no issue also a good concentration of e85. Vs some elses stage2 and only being able to run 21psi on ST 6262. I would say at 26psi he's definitely in the low 600s
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon! |
03-31-2018, 06:03 AM | #21 | |
39
Rep 585
Drives: 2010 335i
2010 335i Coupe / 6MT / MHD | FBO+ MMP S3 /AUBURN WDE / PATRIOTS / CELTICS / REDSOX
03-31-2018, 06:05 AM | #22 |
39
Rep 585
Drives: 2010 335i
granted you're now out an additional $1400 in parts... not ot mention you prob need a better FMIC. but once its done... its done. Enjoy a 93 tune and save up for the rest.
