Battery change, Now I have CELs...
02-26-2017, 01:10 PM | #1 |
619
Rep 1,402
I changed the battery today and hooked everything back up and it started fine and idles fine.
Now have CEL on the dash panel. -triangle with circle arrow around and ! inside, not flashing. Manual says DSC and DTC deactivated -under it is 4x4. manual says xDrive and DSC have failed. Have trans checked immediately. I haven't driven it yet. I think that these just have to reset when I drive but just wanted to be sure. Anyone have any experience or help? Thanks. |
02-26-2017, 01:46 PM | #2 |
238
Rep 947
CEL is not normal from power loss but the DTC/ABS/Brake/AWD errors are normal. The steering angle sensor needs to be reinitialized. Driving a bit turn the wheel lock to lock will reset it
02-26-2017, 03:37 PM | #3 |
1007
Rep 2,108
+1
Turn the wheel all the way to left then and all the way to right, they will go off. It is a ritual needs to be done after reconnecting battery every time. Plus readjust the clock on radio. |
02-27-2017, 06:53 AM | #4 |
619
Rep 1,402
Thanks, Will take it out today for a drive and perform a 'lock to lock'.
I tried hooking up a second battery to the jump points under the hood thinking that that would maintain 12v to the system when I removed the battery. Didn't work. IDK if it was because I left it battery out and jumper on for about 90 minutes or because I had to disconnect all the connections on the battery distribution box which sits on top of the battery. The trunk wouldn't open and had to use the key. This was a failed idea. Will have to rethink this one of wanting to maintain 12v to the system when removing the battery. |
