FMIC with stock connectors?
02-25-2017, 06:59 PM | #1 |
235
Rep 1,328
I am looking for some input on which FMIC will fit my 2011 335 M-Sport. The FMIC must have stock connectors and require little to no cutting.
Thanks,
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
02-25-2017, 08:20 PM | #2 |
hehe ty men
32
Rep 172
I was thinking of getting the AA sport but I'm waiting for andrew to email me back about whether it requires cutting or uses stock connectors. It looks like it does use OEM connectors though!
02-27-2017, 06:09 AM | #5 | |
93
Rep 213
Drives: 2011 335i xDrive
Edit: Sorry, forgot to reply to OP. I know when I was shopping around the Mishimoto FMIC used stock connections, but again it is very pricey. |
02-27-2017, 06:48 AM | #6 | |
114
Rep 399
02-27-2017, 08:31 AM | #7 |
707
Rep 2,449
Doesn't require cutting to fit, but you will have to cut off the band holding one of the factory pipes, as the vrsf intercoolers do not use the factory quick disconnects.
02-27-2017, 11:16 AM | #8 |
26
Rep 135
I had no idea this was an issue, having to cut the ends of the pipes.
How much of a pain is it to do this? Once you cut the ends/quick connects off you can basically fit any intercooler you want on there right?
02-27-2017, 11:19 AM | #9 |
hehe ty men
32
Rep 172
I decided to buy the AA intercooler since Andrew said that the sport doesn't require any cutting and uses oem connectors.
It's $399 shipped from x-ph if they still have stock. You can try emailing mike@x-ph |
WedgePerformance1339.00 |
02-27-2017, 11:32 AM | #10 | |
164
Rep 411
At least that's the cutting I'm assuming everyone is talking about. I didn't cut anything else. |
02-27-2017, 11:32 AM | #11 | |
114
Rep 399
Well that sux,:/ I didn't want to cut anything and considering it takes Tiago 2 days to reply to PM's and there is NO phone number I stuck with cutting the pipes. I probably should have waited on day on this. I thought them being local would have helped, No cause is a "shell" address and the fact they have no phone number should have caused me to wait. If I saw the AA on sale I would have bought that one. |
02-27-2017, 11:47 AM | #12 | |
182
Rep 322
02-27-2017, 11:51 AM | #13 | |
hehe ty men
32
Rep 172
Here's the response from andrew@activeautowerke |
velociti181.50 |
02-27-2017, 11:55 AM | #14 |
182
Rep 322
02-27-2017, 12:04 PM | #16 |
114
Rep 399
So, I'm guessing email is the way with him. Tiago emailed me right back and told me the reason cutting of the stock connections is they have proven to leak about stock PSI and the 1.8 neck down. The VRSF uses 2.75 to increase the overal flow. So sounds like it might be worth it. Thank you Tiago
02-27-2017, 12:06 PM | #17 |
182
Rep 322
For a 5", I'm drawing a blank. The VRSF stepped version might be a bit more effective, but non-stock connections. VRSF's 7" looks killer for the price, but I'm pretty sure that requires cutting, and it might not be ideal for cars with basic mods -- seems like it's a better option for FBO or hybrid turbo builds. The Wagner looks to be a bit more efficient than the AA since it's stepped, but at almost 50% greater cost. For daily drivers like me, the AA seems perfect.
02-27-2017, 12:19 PM | #18 | |
hehe ty men
32
Rep 172
I wanted the wagner because of the design but it was out of my price range |
02-27-2017, 12:24 PM | #19 | |
235
Rep 1,328
02-27-2017, 12:52 PM | #20 | |
707
Rep 2,449
The other type of cutting is due to an intercooler that won't fit in the stock space. This requires trimming of the plastic shrouding to get the intercooler to fit. The amount that needs to be trimmed depends on the intercooler and should be very well known since most intercoolers have been out for a long time. Last edited by houtan; 02-27-2017 at 01:01 PM.. |
02-27-2017, 01:05 PM | #21 |
2097
Rep 43,350
The OEM connectors are are a massive restriction on this platform. They neck down to less than 2" and have proven to leak over 16 psi. The size of the AA core is also very limited. If you're going to go with a 5" core, make sure it's stepped. The extra volume makes all the difference in terms of flow and temperature control.
ANMVQ113.50 |
02-27-2017, 01:17 PM | #22 | |
235
Rep 1,328
Thanks! |
