MHD + Wedge Performance!!!!!
02-24-2017, 10:58 AM | #1 |
235
Rep 1,343
I have just finished working with Ken to create a custom 94 Oct tune for my 2011 335i MT. I have an ER Chargepipe and an n54tuning Catless Downpipe. The car is smooth and very strong for my daily driving requirements.
Here are two of my latest logs... http://www.datazap.me/u/diggler70/lo...og=0&data=4-15 One question I have for the group though is whether I should look to add either a FMIC or meth as a "last" upgrade? Is it worth it or should I just leave things as they are? A big shout out to Ken. Amazing work. Excellent service. Great guy!!!! Thanks,
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
02-24-2017, 11:34 AM | #2 |
114
Rep 399
looks pretty good, I'm finishing mine also( Thread below yours) he's great to work with. FMIC is now on my" must list" getting one installed next week.
I have a CP also but you may want to look a foam drop in filter. Thats the only other mod I have and I'm seeing my MAFgs in the 300's |
02-24-2017, 11:46 AM | #3 | |
69
Rep 226
2011 E90 N55 / Injen intake / PS2 / Pure inlet / VRSF 7" HD FMIC / VRSF DP / FTP CP's / N20 TMAP / BMS OCC / M3 Front Control Arms / Bilstein B12 Pro-Kit Sport Suspension
02-24-2017, 06:13 PM | #4 | |
235
Rep 1,343
02-24-2017, 08:32 PM | #5 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
02-25-2017, 11:07 AM | #7 |
Rep 9
WedgePerformance1334.00 |
02-25-2017, 12:29 PM | #8 |
235
Rep 1,343
I don't think that one will work on my e90. Will have to look to see if they have one that fits my car as I like the idea of having stock connectors for a perfect fit and seal.
02-25-2017, 12:49 PM | #10 |
1334
Rep 1,701
The need for speed is real...
02-26-2017, 10:24 PM | #11 |
166
Rep 1,700
hey bro im got exact same mods as you and im from montreal. ( petro 94 oct too )
id like to get a custom tune just like yours but can someone explain me why timing is so low ? im currently on jb4 map 2 14 psi with 12 degrees of timing but shit afrs and trims ( piggy back i know ) my main concern tho is power haha how this custom map compares to the jb4 map 2 cause boost is 22 psi but timing is low and also i rly want to make the switch since i want safety also |
02-27-2017, 12:15 AM | #12 | |
1334
Rep 1,701
Fuel dictates how much timing you can run. You have a choice, reduce timing or reduce boost. I sent OP a new map to test with stock timing map so he can post a log with higher timing. I'm sure it will make more power but if you're pulling 5 deg across all cylinders you have two choices. Reduce boost or pull timing so it's minimize the corrections. |
DreamerJoe242.00 |
02-27-2017, 09:13 AM | #13 |
235
Rep 1,343
Here are a fresh set of logs from this morning using revision 3 as per Ken's note above about timing. Welcome any feedback as I have no experience or appreciation as to how to read this logs yet.
The car absolutely pulls harder with this revision! http://www.datazap.me/u/diggler70/lo...-10-15&mark=13 http://www.datazap.me/u/diggler70/lo...og=0&data=4-15 Last edited by D's Bimmer; 02-27-2017 at 09:29 AM.. |
02-27-2017, 09:36 AM | #14 | |
166
Rep 1,700
02-27-2017, 09:39 AM | #15 | |
182
Rep 322
02-27-2017, 01:52 PM | #16 |
235
Rep 1,343
Here are four new logs with Revision 4.
http://www.datazap.me/u/diggler70/lo...og=0&data=4-15 http://www.datazap.me/u/diggler70/lo...og=0&data=4-15 |
02-27-2017, 02:09 PM | #17 | |
69
Rep 226
02-27-2017, 07:32 PM | #18 | |
235
Rep 1,343
On a side note, I really like your setup. Had the B12 kit as well. How do you find the FMIC you have?
02-27-2017, 07:58 PM | #19 | |
69
Rep 226
The Mishimoto intercooler has been amazing in the Florida heat compared to stock. Although I have never tracked the car, I have pushed it hard countless times(closed private roads of course ) and have never noticed any heat soak after back to back runs. Most of my recent datalogs were back to back. I am in no way an expert, but IAT's look pretty good to me. http://datazap.me/u/mikaeldarer
02-28-2017, 08:00 AM | #20 |
235
Rep 1,343
Here are three logs from revision 5 this morning.
http://www.datazap.me/u/diggler70/lo...og=0&data=4-15 How is it looking? |
02-28-2017, 11:23 AM | #21 | |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
02-28-2017, 01:34 PM | #22 | |
235
Rep 1,343
