TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Custon 93 Oct Tune Wedge :)
      02-23-2017, 07:14 AM   #1
ANMVQ
ANMVQ's Avatar
114
Drives: 2011 335XI Sedan
Hi guys,
should probably start my own thread about Ken@ Wedge and his custom 93 Oct tune with MHD. He's been great so far and the car pulls really hard,
On my second flash from him and got a log this morning, below is the latest flash. Car is completely stock 59k miles, EX drop in filter and CP. I just bought a BMS intake and will be getting a VRSF incooler installed in a week or so. After that no other mods, ex some type of gauges. Any thoughts on gauges? I was looking at the P3Cars gauges? Thank you
http://www.datazap.me/u/anmvq/log-14...&data=3-6-7-11
Appreciate 4
      02-23-2017, 07:29 AM   #2
bahn
Drives: 2007 E92 335i 6MT
Originally Posted by ANMVQ View Post
Hi guys,
On my second flash from him and got a log this morning, below is the latest flash. Car is completely stock 59k miles, EX drop in filter. I just bought a BMS intake and will be getting a VRSF incooler installed in a week or so. After that no other mods, ex some type of gauges. Any thoughts on gauges? I was looking at the P3Cars gauges? Thank you
Looks solid, nice to see 22 PSI on 93 Ken will get that throttle closure @ 3100 dialed out for you dont worry. I'm glad you've had a positive experience with Ken as well. Car is holding boost nicely as well 18.7 psi @ 4600.
      02-23-2017, 07:47 AM   #3
ANMVQ
ANMVQ's Avatar
114
Thanx man, is the throttle closure something the car normally does? I have read about it but not really sure why it happens? IS that also why I saw timing corrections at the same RPM?
      02-23-2017, 07:55 AM   #4
bahn
In the OTS tunes you'll see throttle closures due to overboost (actual boost > boost target), however Ken is using commanded wastegate on his custom tunes now which from my understanding doesn't utilize boost target.
If you have an automatic transmission it's probably being induced by a torque limit. We ran into that a couple of times on mine, xDrives have it worst as the Alpina flash doesn't increase the TCU torque limits like it does on the RWD cars for some reason. Ken will sort it out
Appreciate 2
ANMVQ113.50
      02-23-2017, 08:23 AM   #5
GripAndRip
Drives: 2011 E90 335xi Auto
Hi guys,
Are you saying you don't even have a chargepipe on it? I specifically bought a CP because of how high he gets that boost. Your stock pipe is holding 20-22PSI??!?!
2011 LCI E90 335xi Auto
| Wedge Performance Custom Tune | Pure Stage 1 | Dinan Free Flow Exhaust | VRSF CP | Secondary Cat Delete | K&N Drop-in | VRSF Catless DP | VRSF 5" FMIC| Stage 2 LPFP |
ANMVQ113.50
      02-23-2017, 08:25 AM   #6
bahn
Mine was on the stock charge pipe as well at 20 psi before I upgraded it lol.
      02-23-2017, 08:28 AM   #7
ANMVQ
ANMVQ's Avatar
114
Opps LOL , I forgot to add that, I do have a CP installed it last week, Stock pipe and 22 PSI would = BOOM!!
Yea I have a Xdrive Alpina Auto, so I guess it's doing that with the TQ limits. I'm sure Ken will iron that out
      02-23-2017, 08:37 AM   #8
GripAndRip
Throttle closures and timing corrections tend to line up as they are both safety mechanisms. Essentially, the car is either seeing overboost or some other issue and is closing the throttle to reduce power. Look at my Dinan logs (overly safe tune), everytime I overboost, it dramatically cuts throttle, and then its a constant battle between demanded power and safety. Unfortunate cause there is so much left on the table. From what I've seen, Ken will have your throttle matching your accel pedal for the entire pull, even through all gears.
http://www.datazap.me/u/gripandrip/g...ta=2-4-5-13-16
This log makes me sad. Look at the throttle closure in response to the long overboost.
Blowing my mind that your chargepipes didn't crack or break. Don't make me regret buying the VRSF CP haha.
      02-23-2017, 08:38 AM   #9
velociti
182
Drives: 2009 E90 M3
Dear lord. I've been stalling on my custom 93 oct tune with Ken so I can get my boost leak sorted at my local shop...think that just jumped to the top of my to-do list...
      02-23-2017, 08:40 AM   #10
flexbrah
hehe ty men
32
Drives: 23 M3 Comp xDrive
Is running that high of a boost bad for the stock turbos? Just wondering because the OTS maps only target 14.5 and this is targeting like 22. Looks awesome though! I was about to pay the $300 for Ken's tune myself!
      02-23-2017, 08:43 AM   #11
GripAndRip
I'm kind of worried about my Xdrive holding me back for this reason. I hope he can remedy it. I don't even have the Alpina flash. Even if he does fix it, I'm hoping that the xHP trans flash comes out for our cars in March and removes the torque limits altogether. Faster shifting doesn't sound bad either. That discussion is probably for a different thread though.
I don't have 93oct here, but I'm hoping Ken can make a Kill map for me using e30 and then maybe a DD map for 91. I wonder how much power he can make on 91.
      02-23-2017, 08:57 AM   #12
bahn
Oh he can and has already fixed it. He ironed out my car, dont worry
      02-23-2017, 09:00 AM   #13
velociti
182
Drives: 2009 E90 M3
Would love some insight on this, too...
      02-23-2017, 09:13 AM   #14
GripAndRip
I think it's more of an endurance vs peak thing and how the turbo is being tapered. You are only hitting that PSI for a brief moment and only when you chose to WOT. If your car is a DD, you probably aren't WOT all the time. It seems like the turbos are holding up for those doing this, and I'm sure there are plenty of links to threads and posts by individuals who have their stock turbos tuned like this.
I'm no pro, so someone else wanna confirm the max PSI for our turbos without causing failure? Also how do you define bad? Immediate failure, or decreased life?
      02-23-2017, 09:27 AM   #15
Mikaeldarer
Mikaeldarer's Avatar
Drives: 2011 e90 335i N55
Looks to be within tolerance of stock turbo. At 22 psi in lower RPM, wgdc is around 60%. At redline, it's around 80%.
      02-23-2017, 09:42 AM   #16
GripAndRip
Not sure if we can use the wgdc curve to tell if it's within tolerance or not. Ken is adjusting the wastegate duty cycle in his tune isn't he?
      02-23-2017, 09:43 AM   #17
bahn
This, most turbo failures are caused by overheating of the turbo bearings/seals. As WGDC increases so do exhaust gas temps. Having a catless downpipe will help reduce exhaust gas temps as well which will add some more safety margins in. The N55 turbos are made by Borg Warner and are not Mitsubishi turbos like the N54's. The N55 turbo is much more robust and reliable than the Mitsubishi N54's.
      02-23-2017, 08:12 PM   #18
flexbrah
hehe ty men
32
So being at 22psi for a brief amount of time would be entirely fine on our cars?
I've been emailing with Ken and about to buy the custom tune but I don't want to run into issues due to running too much boost on the stock n55 turbo.
      02-23-2017, 08:30 PM   #19
Johnny Boost
324
Drives: '21 M850i GC
Wow, you've come a long way since your first post! Congrats!
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      02-23-2017, 08:51 PM   #20
ANMVQ
ANMVQ's Avatar
114
Thanx man! Just took some time, still learning about BMW
      02-23-2017, 08:55 PM   #21
ANMVQ
ANMVQ's Avatar
114
Do it , I also don't think Ken would playing with the life of turbo in his tunes. If the 22 PSI is a problem on the stock turbo he'd turn it down. I don't know how big the stock snail is but I'm sure it's not just blowing hot air at 22 PSI for that short amount of time.
I trust him
      02-23-2017, 10:19 PM   #22
GripAndRip
Flex,
Just tell him the PSI you feel comfortable with. Don't like 22, have him make you a lower PSI map. It's your map, it's custom. Tell him your goals and fears and everything you want the map to be.
