BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Does anyone have swaybars?
      02-21-2006, 06:59 PM   #1
AW330i
AW330i's Avatar
Drives: Alpine White 330i
I understand the idea behind sway bars and I know that they will increase handling but I would like a guage of by how much. So if anyone here has done sway bars on their e90, not other cars, I would like to know what kind of results you got...
      02-21-2006, 07:15 PM   #2
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
Not sure, but I don't think anyone has released any as of yet. I'm looking at the H&R's. I want to upgrade the rear bar when it becomes available, but not the set.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      02-21-2006, 08:13 PM   #3
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
Danny
Eibach actually has a set available for our cars now...Highly considering a set...
1988 E30 M3
Diamantschwartz/Black
      02-21-2006, 08:22 PM   #4
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Oh I forgot about that! Anyhow, can you buy just the front or rear?
Danny
      02-21-2006, 08:30 PM   #5
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
I have only seen the set.
http://www.bavauto.com/shop.asp
***Wallpaper of the month***
1/1/072/1/07
      02-21-2006, 10:50 PM   #6
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
Danny
why would you only buy the rear?? this is coming from the company that was making the sway bars off my car. i think th front sway bars was 5mm thicker and the rear was 2 mm thicker. as soon as they call me back for the install i will tke some pictures and let you guys know how it goes. maker is uuc motorwerks.
      02-21-2006, 11:04 PM   #7
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
I want to take the understeer out of the car. By upgrading just one, you get that, not so much with the set.
Danny
      02-22-2006, 01:28 AM   #8
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
I want to take the oversteer out of the car. By upgrading just one, you get that, not so much with the set.
Danny
when you get wider tires your oversteer go bye-bye...
Long
      02-22-2006, 01:52 AM   #9
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Long
I meant to say "understeer" lol
Danny
      02-22-2006, 01:59 AM   #10
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Understeer is a safety feature most car manufacturers opt for.
The SCCA used to allow Solo II participants to add stiffer aftermarket front anti-roll bars in stock class for this reason.
I am very interested in reducing the car's body roll, but noticed that in two previous cars I did this to, the ride seemed slightly stiffer as well, especially over uneven bumpy roads.
      02-22-2006, 09:32 AM   #11
ward
155
Drives: F
even with the bars, the car will still understeer, just a bit less than stock
      02-22-2006, 09:54 AM   #12
GoBonesGo
What do you do when you see a spaceman?
GoBonesGo's Avatar
Drives: SG/Terra E90 335i Step
Originally Posted by ksfrogman
Understeer is a safety feature...
How so? Not baiting here, I've just never heard that before.
      02-22-2006, 10:01 AM   #13
ward
155
Drives: F
it's easier for most to recover from the nose pushing wide rather than the tail coming out.
it's not the "fast" way around a corner, but it's the easier to control way for most
      02-22-2006, 10:33 AM   #14
GoBonesGo
GoBonesGo's Avatar
Ah, thanks.
      02-22-2006, 10:57 AM   #15
ksfrogman
ksfrogman's Avatar
2006 330i  [0.00]
2006 330i  [0.00]
Right. If the nose pushes forward, at least you'll see yourself going off the road in a straight line.
If the rear end comes around and you lose control, your car can do donuts as it skids off the road.
      02-22-2006, 11:11 AM   #16
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
We all know that most cars even the E90 with zsp is designed for the masses. I understand that understeer is a built-in safety feature, and no doubt helps the average driver. I want to fine tune this car to suit my taste, that's all. I guess you can call me an unsafe radical...for decades...
Danny
      02-22-2006, 02:24 PM   #17
ward
155
Drives: F
I don't know about unsafe Danny,
I think you just want what we all want, a neutral handling car
for some reason, they won't just give us one right out of the box!
      03-14-2006, 05:39 PM   #18
solo2
Drives: 1999 328i
Depends..
It depends on what you are trying to accomplish and what type of driving you do. Personally, I would look at ways to improve the grip at the front of the car instead of removing grip from the rear - specially on a non-M car where you will limit the ability to put power down when you add the rear swaybar.
Better options:
* Tires with more grip. Yes, the car will grip better all around, but the increase in front-end grip will be more noticable.
* Stiffer front swaybar. I know.. I know.. now hear me out. Part of the reason a car will understeer is that the grip of the front tires is reduced due to body roll. As the car rolls, the camber turns positive and the tires grip much less.
* Stiffer springs. Same reason as a stiffer front swaybar.
I have found the stock E90 to be much better on turn-in than the stock E46.
All of that said, I can't imagine a situation where I would stiffen the rear of the car without stiffening the front. In autocross, I would stiffen the front a lot and add a set of better tires (to start).
Hank
Boston BMWCCA Autocross (Instructor, car-slut, .. )
      03-14-2006, 05:49 PM   #19
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Originally Posted by solo2
...I can't imagine a situation where I would stiffen the rear of the car without stiffening the front...
I did this in my last 3 cars and it worked like a charm. All my cars before this has been FWD.
Danny
      03-14-2006, 06:02 PM   #20
ksfrogman
ksfrogman's Avatar
2006 330i  [0.00]
2006 330i  [0.00]
Here's a good link that discusses the effect of sway bars in weight transfer during a turn, and how this affects under- and oversteer.
http://www.automotivearticles.com/12...way_bars.shtml
      03-14-2006, 06:05 PM   #21
larryn
Whose e90 were you making these assumptions on?
Hank
If it was mine, remember I had 255 azenis 615's up front. Trying 275's this season.
      03-14-2006, 08:21 PM   #22
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
275 in front???
