2010 e92 335i forged internals???
02-18-2017, 09:10 PM | #1 |
79
Rep 69
i have a 2010 335i on the door jam says built in 11/09 i had a friend tell me that my internals were not forged like the 07-08's and i could only hold 600hp compared to the 07-08's where they could hold 700 + can anyone confirm or deny any of the info please?
02-19-2017, 10:50 AM | #2 |
90
Rep 632
it a myth.
Some say that N54 all comes with forged crank and rods. Some say only early years comes with forged crank and rods. VAC opened a N54 and found out crank is forged, rods are kinda forged. Only way to find out is to open your engine. |
02-19-2017, 02:21 PM | #3 |
91
Rep 346
N54 crankshaft and CONNECTING RODS are forged. End of story. Virtually no pistons are forged anymore, emissions are HORRIBLE with forged pistons because of all the blow by until warmup.
Crank is clearly forged and rods you can tell because the rod caps are cracked and matched. Build date doesn't matter, the 335is / 1M have the same engine internals. EDIT: somehow typed pistons were forged on accident before.
GOS767.00 |
02-19-2017, 03:23 PM | #4 | |
327
Rep 960
Chris@VargasTurboTech1933.00 |
02-19-2017, 09:47 PM | #6 |
13
Rep 97
Correct. I have an 06 build 2007 335i. BPC is currently finishing the rebuild of my engine. Crank is forged, pistons and rods are not.
2010 E90 335D
2012 E70 Xdrive35D 2014 F10 535D |
02-20-2017, 08:51 PM | #7 | |
91
Rep 346
"Fracture-split connecting rods, however, are manufactured quite differently. The connecting rod is forged as a single piece of metal. Next, using specialized equipment, the large end of the rod is precisely scored. Finally, the cap is then literally ?snapped? from the rod. This process results in an uneven fracture surface on the rod and cap parts. This uneven surface allows for a more precise, durable cap-to-rod fit than is possible with traditionally manufactured connecting rods." I'm not aware of this changing and the ability of different years to sustain loading wouldn't suggest this has changed
05-14-2020, 05:35 PM | #8 | |
54
Rep 130
