VRSF catless downpipe fix - Is it Okay if I leave it?
02-16-2017, 10:50 PM | #1 |
22
Rep 93
Im about to have my catless dp installed. I have the DP Fix from the website, its basically this small box with a couple of wires sticking out. I'm wondering If I can just leave it installed or should I only install it when i need to pass emissions?
02-16-2017, 11:21 PM | #2 |
242
Rep 1,354
I left mine in.
However after a while my car started throwing codes. My Indy looked into it and discovered that the DPFix was remaining on all the time. They hooked it up to a switched circuit so that it is fully powered off with the engine. After doing that, no more codes... and it continues to work fine... readiness goes OK too. |
02-17-2017, 12:18 PM | #3 | |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
02-20-2017, 03:50 PM | #4 |
24199
Rep 190,807
You can leave the N55 plugged in at all times
02-23-2017, 08:32 AM | #5 |
94
Rep 321
Does anyone have any more information on this?
I am picking up a catless downpipe in the spring, but I want to make that that VRSF dp fix works without issues. How easy is the install / uninstall? |
02-28-2017, 06:53 PM | #6 |
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
Why are you using a DPFix on the N55. I have catless DP and achieve readystate without a DPFix and I make them for the N54. LOL
02-28-2017, 07:37 PM | #7 |
94
Rep 321
02-28-2017, 08:01 PM | #8 | |
26
Rep 135
Im almost thinking about a dp fix for the few times I pull the tune for service. |
02-28-2017, 11:27 PM | #9 | |
1334
Rep 1,701
03-01-2017, 07:30 AM | #10 |
94
Rep 321
Your software shuts off the sensor. Your cat says, "Not avail" and evap is incomplete. You will fail emission test. Switch your car to a stock map and let us know how fast your CEL comes on with a catless dp.
03-02-2017, 08:22 AM | #11 |
324
Rep 2,014
Why would he fail emissions? His oxygen sensor is showing as ready. His evap is incomplete because that one takes the longest but most states will pass you with one not ready.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
N54Society448.50 |
03-02-2017, 08:40 AM | #12 | |
132
Rep 573
In Virginia everything has to be ready and complete unless the car doesn't have it of course. Also from what i've read not a good idea to leave it on it'll throw codes. |
03-02-2017, 09:47 AM | #13 |
94
Rep 321
03-02-2017, 05:59 PM | #14 | |
324
Rep 2,014
03-03-2017, 07:36 AM | #15 |
94
Rep 321
03-09-2017, 03:15 PM | #16 |
285
Rep 615
Drives: '11 E92 335xi 6MT
I've been running the DP fix since last summer with no issues.
MHD stage 2 maps disable the CEL for DP codes but they do not show cat readiness for emissions. The way to pass emissions with MHD is to flash back to stage 0 and complete several drive cycles so the ECU can see the O2 sensor signal from the DP fix. This is my emissions readiness with the DP fix: |
01-31-2018, 06:25 PM | #19 | |
24199
Rep 190,807
01-31-2018, 10:27 PM | #20 |
485
Rep 599
I'm confused. So the VRSF downpipe fix should only be out on before emissions?
I thought you connect it to the ECU after installing the downpipes as a permanent solution so your car won't throw codes relating to the DP. I am a n55 btw...
Vermillion Red
02-02-2018, 01:04 PM | #21 |
2124
Rep 2,758
No, as said you only put them in for emissions testing. To get rid of the light on the dash you use a tune like MHD or a piggyback like JB4, you will still have codes but they don't affect anything.
08-17-2018, 11:23 AM | #22 |
18
Rep 87
Well that is new information. I thought you leave DP fix in all the time?
My engine light just came on and my car started idling rough. Is that normal or do I have bigger problems? I left my DME reader at home today. |
