02-14-2017, 11:02 AM | #1 |
39
Rep 115
License plate front bumper holes
Gentlemen,
Yesterday I removed my front bumper plate as I'm looking to add some plugs and get rid of the ugly. As I removed the bumper cover, I was exceedingly annoyed to see that the license bolts that screw into the license plate actually went all the way through and into the bumper. Clearly they used bolts that are too long. I can't plug those holes. Has anyone had a similar experience like this before? It's bad enough that they installed the plate after I specifically requested they don't do it. Now I can't even plug the holes. Is it worth taking it to the dealership or am I SOL and better off just leaving the damn plate on? |
02-14-2017, 11:57 AM | #2 |
102
Rep 303
02-14-2017, 12:35 PM | #3 | |
39
Rep 115
AlexM240i101.50 |
02-14-2017, 01:29 PM | #4 |
4516
Rep 8,942
If you specifically told the dealer not to mount a front plate and they did you should make them fix it. Will need to re clear the whole front after patching and painting the holes.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
walnuttea39.00 |
02-16-2017, 12:01 AM | #5 |
10
Rep 70
I used some bondo and a couple layers of paint/clearcoat to patch mine up in the front.
Was a pain (days of waiting for paint to cure etc) and it isn't 100% perfect, but it's wayyyy less noticeable than the license plate or the holes would've been. The only problem I ran into was I had purchased the car used and the new paint is a teeny bit brighter than the older paint but not by much. You get within 6 inches with your head you can tell but standing up, driving, or walking by no biggie. When I sell it I'll just drill out the filler and remount the plate. Would've preferred to use bumper plugs but I had the same mounting pattern as you so it would've looked a bit odd with 4 plugs that close together. Wouldn't just look like more PDC sensors... |
walnuttea39.00 |
02-17-2017, 08:03 AM | #6 | |
39
Rep 115
02-17-2017, 04:30 PM | #9 |
1165
Rep 1,931
if its mineral, it will never match.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
walnuttea39.00 |
02-20-2017, 08:24 AM | #10 |
39
Rep 115
Well, I walked out the door with the car despite the license plate being installed just because it was a pretty darn good deal and I was ready to swap cars. In other words, I was pissed but made the mistake of accepting the license plate install. I live in the city so I figured it'd be somewhat necessary. Of course, I was also under the assumption that the license plate only damaged the bumper with 2 large holes that could be patched up later. I certainly didn't expect the license plate screws (not the mount screws) to extend all the way into the bumper as well, so that's the big issue.
Not sure if I can complain to the dealer about excess damage to the bumper? I can't imagine that having the plate screws dig into the bumper is standard "practice." Seems like negligence in figuring out proper screw length. |
