BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      04-18-2008, 09:15 PM   #1
OC ///M
Dr. Octagon
OC ///M's Avatar
Drives: Moonstone e92 M3
Transmission Fluid Fill Location
OK, here's a lame one...
When I checking in the "Maintenance" section, I could not find where the transmission fluid fill location was. It seems they forgot to show us this?
Does anyone know if it's the ~17mm screw on the driver's side of the transmission? GregW you out there?
TIA
OC ///M
2013 E92 M3 Individual
Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB
      04-19-2008, 12:11 PM   #2
GregW / Oregon
Commander-In-Chief
2095
TIA
You know I am...I don't have a life! Just kidding.
The following diagram shows the oil pump (#1) and screw filter (#2) just in front of the pump. "The gear oil is replaced and the screw oil filter is checked or cleaned during the running-in inspection, and later according to service specifications (estimated after every third engine oil change)."
They don't want mere Owners messing with this stuff! The filler is generally about midway up on the side (right, I think) of the gearbox (17mm sounds about right). Capacity is a little less than 2 liters, I believe, but I don't have exact specs.
The current fluid is MTF-LT-3 and comes in a 5-liter size (#83-22-7-533-818). If you bring your own container the parts dept. should sell you 2 liters.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      04-20-2008, 03:19 AM   #3
Big Windy
Big Windy's Avatar
Drives: None
greg, where the heck do you find all this stuff???? or do you just make diagrams like this in your free time?
      04-20-2008, 09:54 AM   #4
GregW / Oregon
Commander-In-Chief
2095
Technical info
Heh, heh, heh...from my secret archives! Actually, a lot of the technical stuff I've posted comes from this wonderful document, one of the only ones I've seen that has some good detailed info on at least some technical aspects of the car:
http://www.bimmerfest.com/pdf/BMW-M3...nformation.pdf
The stuff on the filler and lube type is from personal experience.
      04-20-2008, 10:02 AM   #5
Big Windy
Big Windy's Avatar
Drives: None
oh, so this is the M3 Bible I was hearing about. Thanks Greg!
      04-20-2008, 10:54 AM   #6
OC ///M
Dr. Octagon
OC ///M's Avatar
Thank you Greg. That's exactly what I was looking for...I've also wondered where you got these beautiful diagrams.
Sorry, about "expecting you to be there" it's just that you always seem to have the correct answer, usually accompanied with the respective diagram...
Thanks again for coming through with this.
OC ///M
Search this Thread:
Advanced Search
m3post
