02-09-2017, 01:54 PM | #1 |
Rep 23
2012 F30 Turn Indicators Not Working?
Hi F30Post-ers,
I'm a fresh f30 owner. I came from a 2003 BMW 325i and made the leap in to a new (to me) F30 328i. Some family friends were at the end of their lease, and gave me the opportunity to buy it out from them so I did! I did the usual background check on the car and discovered no accidents. It's a 2012 with only 35,000 kilometres on it. Now recently a friend pointed out to me that my turn indicators in the mirrors aren't working, right or left. It's a Canadian market vehicle, if that makes any difference. I don't remember ever seeing them work, is this something that is coded? Or is this a common issue? I've looked around and saw that sometimes water can get in the housing a kill the LED. But it seems suspicious both would be out. |
02-09-2017, 02:03 PM | #2 |
3829
Rep 4,667
Drives: BMW
Wait, what? BMWs have turn indicators?
All jokes aside, if the actual bulb is out or faulty, you should get a fault indication. Do the signals in the dash light up? |
02-09-2017, 03:55 PM | #3 |
Rep 23
No dash codes. The indicators in the headlights, and the taillights work just fine, its only the ones in my mirror that seem to be an issue. Unfortunately I happen to live about an hour out from the nearest BMW dealership. If I can't figure it out by the weekend I'll probably head out there and get it properly diagnosed
02-09-2017, 04:26 PM | #4 | |
2419
Rep 4,463
Drives: '23 X1 28i xDrive
02-09-2017, 05:31 PM | #5 |
no relation
130
Rep 442
What are turn indicators ? I didnt even know my left hand stalk moved up and down
If it's not under warranty, definitely take it to an Indy shop. There should be bunch of Indy shops that specialize in BMW/German cars in Vancouver |
02-09-2017, 06:54 PM | #7 |
126
Rep 367
Apparently this is a common issue. My passenger side one doesn't work. It's actually an LED that lights up a fiber optic cable so you have to change the entire piece, not just the LED. I did this and it still didn't work. A friend who is a BMW tech told me usually it a faulty mirror wire harness...it doesn't bother me at all so I left it alone.
02-10-2017, 04:04 PM | #8 | |
Rep 23
Also, I have a third party warranty that only covers my drive train |
04-05-2017, 06:02 PM | #9 |
Rep 23
UPDATE:
So after spending a weekend tearing both mirrors apart and using a multimeter I have found that the wiring harnesses are supplying both mirrors' turn signals with power, but it seems that either the plugs (Which are weather sealed), or the signal light units are the issue. I suspect it's the latter of the two and replacement signals will be $59,95 each. ALSO I noticed an LCI model F30 with its mirror signal out driving home last week |
04-05-2017, 09:07 PM | #10 |
8264
Rep 16,111
04-05-2017, 09:34 PM | #11 | |
126
Rep 367
Tags |
trumpalufagus |
