Can anyone give me a link to the 2step colder sparkplugs?
02-07-2017, 10:22 PM | #1 |
57
Rep 399
I've seen a few variations but want to make sure I'm getting the right ones for my n55. I gap them to .018 correct?
Mods are pure stage 2, fuel it stage 2, FBO |
02-07-2017, 10:55 PM | #2 |
Normal Person
148
Rep 862
Drives: 2011 E90 335i
Here you go. .018 is working well for me, AFAIK that is the recommended gap for PS2 N55s.
http://www.realoem.com/bmw/enUS/part...&q=12120039664 https://www.ecstuning.com/b-genuine-...s/12120039664/ |
02-07-2017, 11:08 PM | #3 | |
57
Rep 399
02-12-2017, 01:52 PM | #4 |
1207
Rep 2,026
02-12-2017, 04:15 PM | #5 |
Normal Person
148
Rep 862
Oops, sorry about that OP! And thanks for the correction bbnks2. But I thought 1 stage colder was what we are advised to use for PS2 N55s. That is what I am using on mine with good results.
02-13-2017, 09:03 AM | #7 |
Normal Person
148
Rep 862
Again, sorry if I gave you info that was not what you were after. But now you have me curious. When I got my PS2 Dzenno at PTF told me to get one step colder plugs gapped to .018 , and gave me the link I gave you. I'm on my second set now and they have worked well for me since day one. Ken at Wedge is my tuner now, and he said to keep the same plugs, same gap. When and why would one want to go two steps colder?
02-13-2017, 09:20 AM | #8 |
1207
Rep 2,026
The general rule is go 1 step colder for each additional 100hp.
However, the stock plugs seem to work fine for most people even at higher power levels. 1 step colder being a bit safer to prevent predetonation at 500whp+ levels. |
02-13-2017, 12:41 PM | #9 |
Normal Person
148
Rep 862
Thanks for explaining that. 1 step colder is the right plug for me then, hope it is for you too OP!
02-16-2017, 03:00 PM | #10 | |
84
Rep 317
Drives: 2011 E90 335xi Auto
Haven't installed them yet.
2011 LCI E90 335xi Auto
| Wedge Performance Custom Tune | Pure Stage 1 | Dinan Free Flow Exhaust | VRSF CP | Secondary Cat Delete | K&N Drop-in | VRSF Catless DP | VRSF 5" FMIC| Stage 2 LPFP | |
02-16-2017, 09:52 PM | #11 | |
1207
Rep 2,026
Tuning for optimal plug performance becomes harder as the delta between daily driving and wot performance increases. Daily driving could foul up your plugs if they are running too cold. Choosing the right temp plug is best done through observation. Run 1 step colder and see what color the plugs are after 5k miles... are they burnt (white=too hot) or are they fouled (black soot = too cold). Everyone's driving style is different. https://www.ngksparkplugs.com/about-...rk-plug-basics |
02-16-2017, 10:46 PM | #12 | ||
84
Rep 317
02-17-2017, 07:40 AM | #13 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Yes, this is the downside to too cold of plugs. Very few people on here would benefit from 2 ranges colder plugs.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
02-17-2017, 09:09 AM | #14 |
1207
Rep 2,026
02-17-2017, 09:11 AM | #15 |
84
Rep 317
Nice. I couldn't remember if I bought 1 step or 2 step colder and got a little worried. I rechecked the ngk part number and I bought 1 step colder so I'm not worried.
02-17-2017, 10:31 AM | #16 | |
707
Rep 2,448
http://www.1addicts.com/forums/showthread.php?t=1146223 |
GripAndRip83.50 |
02-17-2017, 10:37 AM | #17 | ||
84
Rep 317
