02-03-2017, 03:08 PM | #1 |
229
Rep 625
BMW 340i - JB$ Install
Hello,
Just wanted to hear if this self-install is longer or hard or shorter and easier on the b58 engine. Any links or input? Thanks! |
02-03-2017, 07:23 PM | #3 |
97
Rep 316
Easiest install from my experience. It was my first piggyback install too. Just as easy as the bms intake.
Heck even the downpipe was easy. It took one hour only. Never took the exhaust off either. |
02-04-2017, 08:20 AM | #4 |
165
Rep 413
I'm not incredible at mods and I took a swing at it and it was no problem. Just make sure you disconnect the battery. You'll need a 10MM socket to take off the bolts to access the OBD2 under the steering wheel.
The in engine compartment connections will take 5-10 min for the OBD2 leave it disconnected and feed it back through the firewall from the inside up into the engine area then connect it to the JB4. Use the pics in the install guide take your time it's a 30-40 min install even for a newb first time. I'd def recommend a downpipe and BMS intake to go with it to really unleash the tune.
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
02-04-2017, 07:34 PM | #5 |
BimmerPost Supporting Vendor
24095
Rep 190,633
Self install for sure .. takes 30-40 minutes max
02-06-2017, 11:55 AM | #7 |
107
Rep 498
The only pain in the azz is if you have a stick car, getting the OBD connector through the firewall through the large grommet. Its a royal pain but can be done with a wire hangar and lots of patience, hanging upside down under the dask, and a few scraped up knuckles. LOL
02-06-2017, 02:08 PM | #8 | |
4908
Rep 115,980
Mike |
02-06-2017, 02:09 PM | #9 |
4908
Rep 115,980
02-06-2017, 02:20 PM | #10 | |
107
Rep 498
I had a real headache with mine. |
02-07-2017, 09:12 AM | #11 | |
4908
Rep 115,980
Mike |
02-08-2017, 03:24 PM | #14 |
229
Rep 625
02-09-2017, 08:31 AM | #15 |
4908
Rep 115,980
