02-03-2017, 08:46 AM | #1 |
1913
Rep 2,210
Drives: '17 jackrabbit on crystal meth
wheel HP vs brake/engine/crank/advertised HP
I realize this topic has been discussed and debated ad nauseam throughout the years mostly because the answer is not set in stone. All dynometers are different. But I want to get peoples' input on what they think is the best or most accurate mathematical equation. I hear the "how much horsepower" question seemingly on a daily basis since I've bought my car. Most of these people couldn't differentiate an LSD from a DCT so I want to make it easy for both of us and provide a universal answer, especially since my power numbers are incrementally increasing over time.
My thoughts are as follows based upon this popular position relative to the M2: A 6MT car assumes a 12% drivetrain loss and a DCT assumes a 15% loss. Therefore, if the typical stock M2 puts down 335 WHP, a 6MT unit should advertise 380 HP (335/.88) and a DCT unit should advertise 394 HP (335/.85). These numbers do seem high. I'd appreciate what everyone has to say. Feel free to rip apart my hypothesis if you have better sources.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
02-03-2017, 11:30 AM | #2 | |
497
Rep 358
I've seen lower numbers from other posts on here... so curious if conditions were perfect when I dyno'd or if I have a factory freak. This was bone stock running 93
F87 M2 - LBB - 6MT - Exec Package
insta - @LBB_M2 |
02-03-2017, 11:58 AM | #3 |
1913
Rep 2,210
Yeah, I did 349/367 on a Dynapack, that TQ number of yours is killer....getting a baseline done again on a Dynajet very soon.
02-03-2017, 02:42 PM | #4 |
757
Rep 1,835
Drives: 2020 X4M CS
I personally hate the whole drivetrain loss measured in %....Yes a 400hp dct rwd car may lose a certain amount of hp that equates to 15% bt that doesnt mean when that car is modified to 800hp (crank)that it loses twice as much power to the wheels...
For example an unmodded car (x) looses 30hp to spin the drive train...You modify it and double the hp. Is it magically twice as hard to push? No...z Maybe there are stronger drive train components, or in gear maybe the compression ratio makes it harder to push but from my experiences drive train loss is ridiculous to measure in percentages. Different cars are more effiecient than others st putting the power down, but it shouldnt be measured in %, Hope this makes sense.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
LBBDrew336.00 |
02-07-2017, 07:11 AM | #5 | |
1913
Rep 2,210
02-07-2017, 05:23 PM | #6 | |
536
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
As DKM3Power correctly points out, if you double the stock hp you would not see double the drivetrain loss. However, a flat hp number would not be accurate either since this increase on hp will result in greater internal stresses that do contribute to drivetrain loss. If you are able to pull the guts out of a drivetrain with double the hp you would expect to see higher levels of friction, heat build up, and losses due to increased angular momentum of the drivetrain components. These will increase drivetrain loss and since this increase is non-linear, it is more difficult to calculate than simply assuming a blanket hp figure. One possibility would be to look at several stock M2's results and see what kind of figures they are putting up to then extrapolate how efficient the drivetrain of the M2 averages out. This figure could be used as a baseline for the M2 but would not be applicable to a different type of car since the design of the other car may not correlate with the design of the M2 or with highly modified M2's that may be making significantly different hp figures. |
auf Deutsch1913.00 |
02-07-2017, 07:11 PM | #7 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
auf Deutsch1913.00 DrKevM52274.50 |
02-08-2017, 02:56 AM | #8 |
3179
Rep 2,577
That doesn't explain the fact that 6MT m2 reads normally 5~10hp lower on the wheel than its DCT counterpart.
Lemania 2320
02-08-2017, 01:38 PM | #9 |
1913
Rep 2,210
How accurate is the horsepower calculator on the dragtimes site?
12.0 ET 116 trap 3600 lbs equals 425 flywheel
02-09-2017, 02:54 PM | #10 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Where's the 3% extra loss coming from with the DCT? It doesn't have a Torque Converter...
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-10-2017, 07:48 AM | #11 |
1577
Rep 3,888
02-10-2017, 07:58 AM | #12 |
1913
Rep 2,210
This is just a random example. All numbers are interchangeable.
02-10-2017, 08:17 AM | #13 |
1577
Rep 3,888
