02-02-2017, 08:35 PM | #1 |
13
Rep 19
Dyno question:
for those of you whom had your M2 on the dyno, which geardid you use? We had mine on the rollers today and the gentleman used 4th gear. I heard someone mention using 5th so it made me wonder what would be the right way for this car.
02-02-2017, 08:37 PM | #2 |
292
Rep 254
For DCT you are supposed to use 5th. I don't know about manual
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough 2008 VW GTI - first experience with boost 97 Integra GSR - crashed it |
02-02-2017, 10:50 PM | #5 |
260
Rep 290
5th for the DCT. You'll get lower numbers in the other gears
I had two pulls in 5th and one in 4th. The 4th gear pull was ~15 hp and 50 lb/ft lower than the 5th gear pulls. |
02-02-2017, 11:20 PM | #6 |
IG @bmwF9xG80
3813
Rep 7,593
DCT & Manual def 5th gear
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
Norcalmav23292.00 |
02-03-2017, 09:04 AM | #7 |
BimmerPost Supporting Vendor
966
Rep 13,780
yes you always want a 1:1 gear ration which for the M2 is 5th gear in both manual and DCT
Norcalmav23292.00 |
02-03-2017, 12:05 PM | #8 |
25
Rep 36
100% sure dyno must be done in 5th gear for M2 in both manual or automatic
All dyno stands require measure to be done in the closest to 1.00 gear. In some cars can be 4th or 6th but more than 50% is 5th See jpg atached. Is extracted from PDF attached |
