BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 400hp N55 reliability
      02-02-2017, 04:54 PM   #1
Aseneph
Aseneph's Avatar
37
Drives: 2012 BMW 335i Coupe
Safest way to 400hp N55
I just purchased a 2012 BMW 335i coupe. I'll be using it as DD so I'm wanting to stay as far away from issues as I can but I also want more power. What would be the safest way I could reach 400+hp? I was thinking DCI, FMIC, MHD, then Catless DP in that order.
      02-02-2017, 05:33 PM   #2
Johnny Boost
324
Drives: '21 M850i GC
Did you mean 400 HP to the wheels or the crank? if you meant to the crank then yes those mods will get you there with pretty good reliability if it's tuned properly. I highly recommend getting a custom tune with e85. if you want 400 to the wheels then you'll need an upgraded turbo. N55 has a single intake so no DCI.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
Appreciate 2
Aseneph36.50
FSociety3812.50
      02-02-2017, 06:08 PM   #3
BoosTonian
BoosTonian's Avatar
Drives: 2017 MB C63 S AMG Coupe
^^above poster is correct.
n55 will max out around 380ish whp. need an upgraded turbo to reach 400whp (at least on the e-chassis).
Stage one will get you into the low-mid 400s (40-75whp above stock turbo depending on fueling) while stage 2 will net you as much as your fueling permits (600+whp).
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330
      02-03-2017, 12:06 AM   #4
Aseneph
Aseneph's Avatar
37
Sorry for not specifying but yes I meant to the crank. And thanks for the help! Is there anything else I could do just to make sure everything runs efficiently and smooth?
      02-03-2017, 07:48 AM   #5
BoosTonian
BoosTonian's Avatar
Make sure maintenance is up to date. Specifically spark plugs so that you aren't misfiring all over the place.
      02-03-2017, 07:50 AM   #6
Johnny Boost
324
You'll want to upgrade your charge pipe before you tune it.
Appreciate 2
ANMVQ113.50
DOCTOR.Y102.50
      02-03-2017, 09:57 AM   #7
Aseneph
Aseneph's Avatar
37
I was thinking of getting an ER FMIC with the upgraded CP and DV for my first mod
      02-03-2017, 11:43 AM   #8
GripAndRip
Drives: 2011 E90 335xi Auto
Are you saying the PS1 upgrade will only net him 375whp?
2011 LCI E90 335xi Auto
| Wedge Performance Custom Tune | Pure Stage 1 | Dinan Free Flow Exhaust | VRSF CP | Secondary Cat Delete | K&N Drop-in | VRSF Catless DP | VRSF 5" FMIC| Stage 2 LPFP |
      02-03-2017, 11:49 AM   #9
GripAndRip
Scratch that 400-420hp with 15% loss assumed. So even worse, 340-357 WHP?!
      02-03-2017, 03:53 PM   #10
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
No, he is saying mid 400whp which has never been achieved yet. You will not see 600+whp on a PS2 either. His numbers are pretty high. PS1 max so far is at 426whp and PS2 seems pretty topped out at 560whp. Those are both being pushed extremely hard and aren't DD numbers.
For 400 crank hp do the charge pipe, tune, dp and fmic. If you have at least 93 oct you are going to be right around 400hp (340whp). If you are stuck with 91 oct you will probably need meth injection to get there and it will take you a bit higher even. If you have E85 available you can hit 360whp easily.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      02-03-2017, 04:03 PM   #11
Aseneph
Aseneph's Avatar
37
Yeah I only have 91, and e85 around me. But thanks for the help!
      02-03-2017, 04:09 PM   #12
GripAndRip
I plan on running an e30 map for those numbers. I won't be doing a pure turbo upgrade for a while.
      02-03-2017, 06:35 PM   #13
BKBMW335I
Drives: '11 E93 335I
Do you have any idea of what type of hp/tq numbers to expect with MHD e85 tune, dp, fmic, running the 93/40% meth mix??
Mods: MHD Stg 2, xHP Flashtool Stage 3, VRSF 3" Chargepipe, Megan 4" Downpipes, Pure N55 Inlet, Outlet, VSRF 5" Stepped Intercooler, GFB Diverter, BMS N55 Intake, Michelin Pilot Super Sport Tires, BMS Sport Oil Cooler Valve, CF Spoiler, CF Kidney Grille, CF Mirror Covers, CF Eyelids, CF Wheel Hub Covers, CF Diffuser, M Sport Racing Strip, 20% Tints, and Golf Tee Mod
      02-03-2017, 07:52 PM   #14
weehe126
1161
Drives: 2017 340i
370whp max
RMNB365.00
      02-03-2017, 08:49 PM   #15
BKBMW335I
Originally Posted by weehe126 View Post
370whp max
Thanks bro, I'll take it.
      02-05-2017, 11:45 AM   #16
RMNB
RMNB's Avatar
365
Drives: 2021 440xi CPE BSM
370whp max
This is where I am now. Frank at TechTuning maxed it out with what I have installed. Can't hammer it from a stand still cuz bits would be flying all over the road. 1 800 new differential. Running 93, nothing else special. Pulls hard but I need some work done. Plugs, coils, re-flash etc. Get rid of a mid range stutter. Read my sig...all I can really do with the N55 based upon what I am running. Keep it for a few years then in to a my M dream car!
      02-05-2017, 03:36 PM   #17
DrRobert
Normal Person
Drives: 2011 E90 335i
2011 E90 335i  [0.00]
If you get the ER FMIC get the black anodized version, looks sweet cuz you can't see it through the grille!
      02-05-2017, 03:57 PM   #18
orteeze
223
Drives: 2018 YMB F80
Link to the 426whp with PS1 please!
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD
2011 BSP 335i-SOLD
2011 BSP 335is- FOR SALE
2018 YMB M3- Current
      02-05-2017, 11:24 PM   #19
aaron_
90
Drives: E93 335i LCI
My cars all blacked out. Have a chrome fmic. Love it !
      02-06-2017, 07:58 AM   #20
DrRobert
Normal Person
To each his own. My car is not blacked out at all. I love not seeing the FMIC through the grille!
      02-06-2017, 08:00 AM   #21
JETmn
2011 335Xi  [0.00]
That was a long time ago before the PS2 came out. The next highest was 408whp I believe. I think the 426 was probably a high reading dyno. It was a FBO E series N55 with a very aggressive tune.
      02-07-2017, 01:51 AM   #22
Bours
166
Drives: 2011 335i x-drive LCI sedan
370 whp or 370 at the crank ? Jb4 or flash only ? How much boost ?
