01-24-2017, 06:26 PM | #1 |
BimmerPost Supporting Vendor
3847
Rep 54,376
Drives: F80 M3
Ultimate Clutch Pedal for your E87 M2
…a must for all modern “Sporty-Driven” (manual) BMWs.
The “Ultimate Clutch Pedal” is a short-throw clutch pedal made of billet aluminum and 6061 aluminum tube. It fits all LHD manual BMW 3-series cars 2007 and up. Includes (E90/92 and up including F-models) along with all manual 1-series cars and X1 chassis. “Slop” is completely eliminated by the use of precision maintenance-free bronze bushings and stiff billet CNC-design pivot block. Feel is greatly increased due to the elimination of all plastic and flex in the pedal system. The slightly shorter throw makes for quicker shifting and a more positive feel. Lower pedal resting location (15mm lower) lines up pedal better when braking and requires less “leg-lift” from the dead-pedal. The over-center spring is user adjustable with 3 settings (Stock - Sport - Race). Includes adjustable clutch stop that allows user to fine-tune the pedal travel distance and carpet clearance. Satin tumbled surface is then finished in anodized black. Pedal pad shape is compatible with OEM rubber or any after-market pedal pad kit. Easy end-user installation requires no alterations to the car and no special tools. Race-proven performance – positive feedback… Tested by amateur and professional racers. |
01-24-2017, 06:39 PM | #2 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
I need two.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
01-26-2017, 11:18 PM | #4 |
3847
Rep 54,376
Drives: F80 M3
Can't post prices in this section.
It's listed here: http://f87.bimmerpost.com/forums/sho...light=ultimate |
02-01-2018, 11:21 AM | #6 |
94
Rep 412
interested, however ive heard of the transmission syncro issues that people have talked about when installing the BMS clutch stop. Would this product have similar repercussions? or is there something different int he design that prevents the premature wear on syncros etc... ( i understand these are two completely different products, BMS clutch stop vs the entire clutch pedal)
Thanks! |
02-01-2018, 01:48 PM | #8 | |
Former P-Car Owner
272
Rep 237
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped |
02-01-2018, 08:40 PM | #9 | |
3847
Rep 54,376
Drives: F80 M3
K9GunSlinger93.50 |
02-02-2018, 01:11 AM | #10 |
94
Rep 412
02-02-2018, 09:02 AM | #11 |
92
Rep 177
Drives: Long Beach Blue M2
Seconded. What is the proper shifting technique? I don't think I'm causing damage to the synchronizers, and I haven't installed my clutch stop yet, but I only just started learning to drive manual.
02-03-2018, 09:01 PM | #12 |
78
Rep 127
Best way to learn is to attend a local HPDE event, your instructor can show you how to shift properly. You're in OC so plenty of track days in the area.
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition |
02-04-2018, 05:53 AM | #13 |
384
Rep 573
Drives: 2018 M2
Putting fire-proof underwear on here: The POTENTIAL issue for the clutch stop is that it is POSSIBLE that the clutch stop is too high which COULD stop the clutch from fully disengaging - meaning the clutch COULD be always dragging and the shafts COULD BE spinning with more resistance that they should be POTENTIALLY causing premature wear to the synchros. If you know that it's not dragging, you're good. This pedal likely would have no impact on that aspect if the travel is allowed to go through it's full range of motion allowing the clutch to fully disengage.
02-05-2018, 10:16 AM | #14 | |
3847
Rep 54,376
Drives: F80 M3
02-05-2018, 01:57 PM | #15 | |
1787
Rep 1,718
02-05-2018, 05:42 PM | #16 | |
384
Rep 573
Drives: 2018 M2
You're not missing anything - my phrasing may have been confusing. I wasn't referring to when the pedal is released, but depressed. |
02-06-2018, 05:59 PM | #17 |
508
Rep 929
So what's the trick to remove the plastic covering that hides the top of the pedals, I found 2, 10mm nuts but can't contort myself to get a good view. TIA
02-06-2018, 06:15 PM | #18 |
384
Rep 573
Drives: 2018 M2
It's much easier than that. Just push up (towards the dash) where the plastic cover meets the carpet by the clutch pedal arm/lever and you'll see the nickel/dime sized white rubber piece that comes out rather easily. No tools needed (maybe a flashlight).
02-06-2018, 07:04 PM | #20 |
384
Rep 573
Drives: 2018 M2
02-08-2018, 09:14 AM | #22 |
508
Rep 929
After removing the two 10mm nuts, the cover needs to be lifted past the two studs that the 10mm nuts attach to, once that is done there are three spring clips that attach the cover to the piece above it, takes some finesse but they pop out, unplug the two connectors and move the lower trim panel from the foot well. Once done the fun begins. Just an FYI.
M2guru383.50 |
