01-24-2017, 07:53 AM | #1 |
Rep 7
M2 and heat stress
I live in Australia (Brisbane). We are into the tail end of summer and have noticed that she (M2) doesn't like the heat/humidity from time to time. I've been advised (through a tuning house) to change the inter-cooler to a Wagner inter-cooler, as this one is far thicker and has more cooling cores and provides far better cooling and better performance with a tune. Thoughts anyone...
01-24-2017, 08:08 AM | #2 |
95
Rep 176
I recall Matt Farah mentioning the M2 being particularly susceptible to heat-soak in his initial review of it. First time I've heard that claim verified by an owner.
01-24-2017, 09:23 AM | #3 | |
7909
Rep 11,785
For example.. street .. or track. Cruising or getting on it.. or ...perhaps just while sittting in traffic? ! ? What are the ambient temps and humidity and what is the car doing /saying. ? |
01-24-2017, 09:34 AM | #4 |
S0THPAW
8723
Rep 7,847
Maybe in springtime I'd go for a bigger IC, this one:
http://www.lightweight-titanauspuffa...mw-m2-f87.html But atm 16:30 CET it's zero (0)degrees Celsius overhere, that's 32F? So no worries Cheers Robin |
01-24-2017, 09:46 AM | #5 |
Rep 7
I've just noticed that sometimes she seems to be not as a responsive as other times (just driving around town/cruising). It appears to be the case when it is a very warm day. Above 28 degrees Celsius, and with humidity very high. To me it's a little frustrating, but something I can deal with. I will put in a new inter-cooler at some stage...
01-24-2017, 10:07 AM | #6 | |
3179
Rep 2,577
Lemania 2320
01-24-2017, 10:11 AM | #7 |
S0THPAW
8723
Rep 7,847
https://trackparts.ch/Wagner-Competi...-335i-F30-EVO2
I'm not sure but are the LC and Wagner the same IC?? Cheers Robin |
01-24-2017, 02:41 PM | #8 | |
436
Rep 571
01-24-2017, 04:18 PM | #9 | ||
7909
Rep 11,785
You're not gonna be able to defeat the laws of physics by simply adding a larger intercooler. I've taken my 1M out on a track day in temps over 100 degrees with humidity. That would be above 37 degrees Celsius in Australia. While the car didn't feel as fast, I began watching my speeds at the end of the straights and they were indeed the same as with cooler conditions. More than likely the vehicle just FEELS a bit sluggish and is still performing admirably. I think OP just has the mod bug |
01-24-2017, 04:56 PM | #10 | |
436
Rep 571
And your point on your speeds being the same at the end of the straight is a good one. This is most likely because of the forced induction and intercooler being able to do its job in not getting heat soaked by way of a constant airflow passing through, something that won't happen on short pulls. |
01-24-2017, 07:32 PM | #11 | |
28
Rep 51
01-25-2017, 12:02 AM | #13 |
28
Rep 51
how do you know your m2 doesnt like the heat and humidity?care to share?
i reside in singapore.avg temp year round on the high can be 33-34 degrees and extremely high humidity. my previous AMG in malaysia sepang F1 track only manages 1.5 laps before engine oil hits 130 degrees. |
01-25-2017, 12:27 AM | #14 |
S0THPAW
8723
Rep 7,847
Interesting. And yes in summer my car feels less in anything minus grip and traction...
Atm with the 18 inch wintersetup and about -1 Celsius/ 30 Fahrenheit it's bloody fast. Cheers Robin |
01-25-2017, 01:58 AM | #15 | |
70
Rep 95
This Spring I will go for a Wagner IC too (Evo I Competition I was thinking, no ECU tuning). |
01-25-2017, 06:50 AM | #16 |
80
Rep 270
over here, its hot and humid. Over +30 degrees celsius anyday. Still have not experienced any heat soak issues. At least, not that i am aware of. Did a track day about a month ago. Pushed the car hard. many 12-15 minute sessions. No problems. only mod: castrol srf liquid. Was pretty happy.
M3 Adjuster7909.00 |
01-25-2017, 07:56 AM | #17 |
7909
Rep 11,785
01-25-2017, 08:16 AM | #18 |
95
Rep 176
Would be keen to hear from Prodigy. about how it feels in Perth. High 30s is the norm for Summer with occasion 40+ degree days. No real humidity though.
01-25-2017, 08:20 AM | #19 | |
3179
Rep 2,577
In fact, your observation is correct, m2 is pretty good at managing engine heat. Though IAT is a known issue.
Lemania 2320
01-25-2017, 02:55 PM | #20 |
1010
Rep 1,563
I get heatsoak on track if I raise the boost, but not under stock power levels.
I am currently working with CSF radiators to produce a custom M2 Oil cooler, DCT cooler, radiator, and intercooler. I used their stuff on my previous car and it was the only way I got it performing properly under hot conditions when the boost went up. |
M3 Adjuster7909.00 SteveVai2.50 |
