Installing JB4 and N55 VRSF Catless Downpipes
01-23-2017, 12:03 PM | #1 |
Boost Marauder
11
Rep 36
How long on average should it take for a good tune shop to install the downpipe and JB4 without worrying about creating a custom map, dyno testing, etc.?
01-23-2017, 12:21 PM | #2 | |
20
Rep 100
Goodluck, Dylan |
01-24-2017, 12:34 AM | #3 |
BimmerPost Supporting Vendor
24198
Rep 190,807
3 hours max for both ... You should save money and just install the JB4 yourself its pretty straightforward
01-24-2017, 08:49 AM | #4 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Yeah, I can do the JB4 in 20 minutes now, it is pretty easy. Since you are Xdrive the DP is a bit harder, but still less than 5 hours.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
01-24-2017, 03:01 PM | #6 |
Boost Marauder
11
Rep 36
I already had the modifications made since my 335 is xdrive for the VRSF catback and the shop that works on my car said we shouldn't have any issues with installing the down pipe. They said they should need my car for 1-2 days but i'm hoping they can get it done within the same day (dropping it off in the am and picking it up early evening) since its my only vehicle on a day where they aren't as busy.
01-24-2017, 03:35 PM | #7 | |
3441
Rep 79,211
Jimmy Splash10.50 |
01-24-2017, 03:41 PM | #8 | |
57
Rep 399
Jimmy Splash10.50 |
01-24-2017, 03:56 PM | #9 | |
Boost Marauder
11
Rep 36
01-24-2017, 03:59 PM | #10 |
Boost Marauder
11
Rep 36
I would like to experiment and install it myself, but the shop ordered it plus the DP so i might as well just let them install it. I'd feel kind of awkward saying yeah install my DP but I want to do the JB4 on my own when they can do it within 10-15 minutes probably you know what I mean?
01-24-2017, 04:01 PM | #11 |
223
Rep 1,073
An experienced mechanic should be able to do this in 2hrs; 3hrs tops on their first try!! I just replaced my VRSF with a Cobb on my back in the garage in a little over 2hrs.
Agreed, install your own JB4.
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD 2011 BSP 335i-SOLD 2011 BSP 335is- FOR SALE 2018 YMB M3- Current |
01-24-2017, 06:36 PM | #12 |
24198
Rep 190,807
+1 it gets a lot easier once you install it a couple of times
01-24-2017, 07:13 PM | #13 |
Member
87
Rep 155
Drives: BMW M3
Took me about an hour and a half on first JB4 install (Had issues so took awhile to fix those, not install issues) I took my Downpipe to a shop and they took roughly hour and a half-hour 45.
E92 M3, 958 Cayenne S, 1966 & 1968 Mustang @ 958.shane
Jimmy Splash10.50 |
01-30-2017, 12:49 PM | #16 |
Boost Marauder
11
Rep 36
Should I have problems installing the DPs for Xi even though I already had modifications done when i had the VRSF catback installed to fit the stock downpipes for Xdrive? From what the shop said after i took care of that I shouldn't have a problem with installing the downpipes but thought i'd just ask for another reference.
03-15-2017, 06:36 PM | #17 |
58
Rep 165
Took me around 2.5 hours for the dp. This was while on a lift and taking my time. I have xDrive, so I partially dropped the subframe [left the bolts about 1/4 of the way in] just enough to be able to wiggle the stock cat out, what'a big sucker that stock cat is. The catless dp was a million times easier to put up in there and fit, like a toothpick compared to the stock cat.
Also the V-band clamp was at a slightly odd angle, and I could barely get my hand in there from the passenger side fender well [took passenger wheel off], just took a bit of patience and lots of short turns of the wrench.
JB4 ISO Map 7 @ 20psi, MHD/BMS e85 BEF, ISO_14 Firmware, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF Catless DP, VRSF 7in. FMIC,
03-26-2017, 10:39 AM | #18 |
79
Rep 247
Hi Guys,
I did the downpipe install over the weekend on my e92 RWD. Installed the VRSF catless (Thanks Mike at x-ph!). Took me probably 4 hours to do by myself. I started the removal at night which probably wasn't the best idea. Also, i really should have had a deepwell socket and a better wrench to assist with popping the transmission bolts. Having the right tools would probably have gotten me around 3 hours. I used a jack and two stands. Dropping down the o2 sensors cables were very easy especially if you have installed a jb4 before. I could not imagine trying to undo these on the stock dp due to space limitations. Removing the old dp is pretty easy.... except the clamp. Getting to that damn clamp bolt was a nightmare but I did it without removing anything extra or lowering sub frame. Once you learn the secrets and spots of where to put your hands and tools it goes fairly smoothly. The VRSF one goes in easier because its smaller and allows more work space. However, putting the clamp back on the VRSF pipe was a pain too but i used my jack to help lift it into place while i aligned the two. I never would have imaged how heavy the stock one is, i dread the day if i ever have to put it back in. Since the install I have not done any open high way driving but did take it around the area on map 2. It pulls harder and feels smoother. The sound is much meaner and deeper. Now its starting to sound like a race car! Super happy so far. My only complaint is the smell, for people who say it doesn't smell I need what you are smoking. My fiance comes back from a vacation today and I just cant wait to hear what she has to say when she smells it In the end ii recommend you do it yourself. When you are down there you you get a nice glimpse of the engine and its parts. You start to understand it and you realize it is not so complicated. This will give you the confidence to wrench and fix your future issues or mods. |
03-26-2017, 10:05 PM | #19 | |
24198
Rep 190,807
Awesome, congrats!!
