The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 2C58 2C86 after Pure Stage 2 install. need 3.5 bar TMAP help
      01-19-2017, 09:35 PM   #1
JLGM4
57
Drives: 2016 M4
Pure stage 2 install done with fuel pump. Got the 3.5 bar TMAP and the adapter but the adapter does not fit the JB4 connection whatsoever. Also what is weird, is that my new 3.5 bar fits the JB4 connection perfectly, which it shouldn't because that is what the adapter is for. Here's a picture of JB4 connection and adapter that will not connect to each other.
Throwing codes 2C58 2C86 and really just want to get this all sorted as I've been without a car for 3 weeks now waiting for this install.
Can anyone tell me why this TMAP connection is not working or if I'm doing something wrong because I'm hoping the codes are related to the TMAP chargepipe connection.
      01-19-2017, 09:58 PM   #2
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
The adapter isn't needed for all cars.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      01-19-2017, 09:59 PM   #3
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
The adapter is for typeA harnesses. If you are typeB then no adapter is needed. You do need to enter the JB4 setting for a 3.5bar sensor though.
Mike
      01-19-2017, 10:00 PM   #4
Rob_BMW_PNW
127
Drives: 135i 2011
You only need the adapter if you have a 'Harness A' JB4, if your JB4 is 'Harness B' it will plug right in without one.
2011 135i N55 Pure Stage 2 Turbo, Stage 2 LPFP, N54tuning.com Catless DP, Cobb Drop in, AEM Meth Kit, MHD, BMS OCC, Tuned by WedgePerformance
PI, LSD, and Dif lockdown coming soon
      01-19-2017, 10:14 PM   #5
JLGM4
57
Drives: 2016 M4
Mike
Got it. That helps. I left the shop with the JB4 plugged into the new 3.5 bar TMAP and was still getting codes so I guess the problem is elsewhere. Could I possibly have to download the BEF to accomodate the new turbo? I've already adjusted JB4 settings for new TMAP.
      01-20-2017, 08:10 AM   #6
weehe126
1161
Drives: 2017 340i
What JB4 firmware are you on? 2C58 is for boost pressure deactivated. Could be caused by the wastegate controller not being plugged in, or from the 2C58 code. Which is TMAP reading below barometric pressure. Could possibly have a bad sensor. I would install the stock sensor to check.
      01-20-2017, 08:12 AM   #7
JLGM4
57
Drives: 2016 M4
Firmware is old i just realized. Need to cut my diode and update this morning and see if that fixes
      01-20-2017, 08:53 AM   #8
weehe126
1161
Drives: 2017 340i
That would do it.
      05-01-2017, 09:10 AM   #9
hz_diesel
192
Drives: 2012 E92 335ix
was this solved? I am having a similar issue, my jb4 is up to date and the diode is cut
      05-01-2017, 09:29 AM   #10
bbnks2
1207
Drives: 135i N55
No idea what JB4 does, but I found that even though my N20 TMAP plugged right in to my stock harness, the pins were reversed. N20 TMAP did not work with MHD until I re-pinned the stock connector:
This may not be necessary with jb4 though?
Here is the thread I wrote on it:
http://www.e90post.com/forums/showthread.php?t=1368216
      05-01-2017, 10:16 AM   #11
hz_diesel
192
Hey, appreciate the response. I believe you scenario is for harness A, I don't think harness B fits reversed but I could be wrong. Harness A requires an adapter where Harness B does not.
      05-01-2017, 10:41 AM   #12
bbnks2
1207
Drives: 135i N55
I am indeed harness type A.
If your plugs fit together fine without the adapter then aren't you harness type A? you said it fit without the harness?
      05-01-2017, 10:45 AM   #13
hz_diesel
192
I am not the OP. I just joined this convo today, I said I have a similar issue as in I am also getting the 2C58 code but I am 100% harness B
