Thermostat Replacement
01-19-2017, 10:56 AM | #1 |
10
Rep 62
Hi - my water pump recently stopped working on my '08 335xi, so I bought a new thermostat while I was at it and had my local indy shop replace both. Water pump works fine now, but the new thermostat is stuck open, thus, I need to have the work done again to replace it... Does anyone know if the one-time use bolts need to be purchased again for a thermostat-only replacement (i.e., does the water pump need to be removed as well)?
Thanks |
01-19-2017, 02:51 PM | #2 |
595
Rep 1,693
How sure are you that the new thermostat is stuck open and that the DME isn't targetting a low coolant temp due to a fault? Have you checked for fault and shadow fault codes?
01-23-2017, 10:00 PM | #4 |
Driving cars and riding bikes really fast
285
Rep 1,002
Did you run the test to check the new water pump?
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
01-24-2017, 01:31 AM | #5 |
595
Rep 1,693
01-25-2017, 11:03 AM | #6 |
10
Rep 62
01-26-2017, 10:10 PM | #8 |
595
Rep 1,693
