01-16-2017, 07:13 PM | #1 |
Moderator
4092
Rep 1,973
OFFICIAL: 5 Series 520d EfficientDynamics to be launched this spring
From the BMW Press Site: https://www.press.bmwgroup.com/globa...spring-of-2017
Market launch of the efficiency champion of the new BMW 5 Series: BMW 520d EfficientDynamics Munich. From the spring of 2017, the new BMW 5 Series, the sportiest and most innovative business sedan in its segment, will also set new standards in terms of efficiency. The new BMW 520d EfficientDynamics Edition impresses with a combined fuel consumption level of 4.3 to 3.9 litres per 100 kilometres - 54.7 to 60.3 US mpg or 65.7 - 72.4 UK mpg (combined CO2 emission level: 114 – 102 g/km). BMW 520d EfficientDynamics Edition: greater driving pleasure, less CO2. As from March 2017, the driving pleasure that is characteristic of the new BMW 5 Series Sedan will be combined with the lowest fuel consumption and emission levels in this vehicle segment. The new BMW 520d EfficientDynamics Edition is powered by a 2-litre, four-cylinder diesel engine featuring BMW TwinPower Turbo technology, delivering a maximum power output of 140 kW/190 hp and a peak torque of 400 Newton metres available between 1,750 and 2,500 rpm. The Sedan accelerates from 0 to 100 km/h in 7.5 seconds and achieves a combined fuel consumption of between 4.3 and 3.9 litres per 100 kilometres and CO2 emission levels of between 114 and 102 grams per kilometres (figures as per EU test cycle, depending on selected tyre size). The power unit of the BMW 520d EfficientDynamics Edition features, inter alia, a turbo charger mounted on anti-friction bearings, high pressure exhaust gas recirculation, a map-controlled oil pump and further developed Common Rail direct injection technology, the solenoid injectors of which ensure precise fuel dosing with a maximum pressure of 2,000 bar. In addition to the optimised efficiency of both the engine and the standard 8-speed Steptronic transmission, enhanced aerodynamic characteristics as well as the Sedan’s greatly reduced weight vs. its predecessor also contribute towards achieving the favourable fuel consumption and CO2 emission levels. Moreover, in order to optimise emission behaviour, the BMW 520d EfficientDynamics Edition is equipped with BMW BluePerformance technology, which in addition to the particulate filter, an oxidation catalyst and a NOX storage catalyst, also features an SCR catalytic converter with AdBlue injection technology reducing nitrogen oxide emissions even further.
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
