BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Oil Level Sensor
      01-12-2017, 11:12 AM   #1
WiL335i
Drives: 2011 335i Coupe Alpine White
Oil Level Sensor
I've noticed in the last 2 oil changes that my oil level no longer shows "Max" level. I always put 6.5 quarts and it always shows it at "Max" level and now it only shows this in the picture. I checked for leaks and I don't have any. The car doesn't burn oil. Does this mean the oil level sensor is about to go out? I currently have 72,000 miles on the car. It's an E92 N55.
      01-12-2017, 11:29 AM   #2
weehe126
1161
Drives: 2017 340i
The window from min to max is only 1 qt. Maybe you are getting an extra .25qts out now when draining. There is nothing to be concerned with.
      01-12-2017, 07:27 PM   #3
WiL335i
Now the level got lower. It's now closer to the minimum level. I re-checked the engine for any leaks and I can't find any. I'm really suspecting the oil level sensor now. I'm surprised that no one else responded to see if they have experienced this and what solved their issue. I just want to know before I buy a new sensor.
      01-12-2017, 08:25 PM   #4
weehe126
1161
Drives: 2017 340i
The oil level is calculated by how fast the oil heats up. There are a lot of factors that can make it off by 0.25 qts. Not to mention most cars consume a quart between oil changes. I really think you are looking for problems.
      01-12-2017, 08:30 PM   #5
WiL335i
Huh? I just changed the oil. There is no way the engine consumed that much oil that fast. Also, the oil level will not show on the display unless the engine reaches the proper temperature.
      01-12-2017, 09:32 PM   #6
weehe126
1161
Drives: 2017 340i
Yeah i get you just changed the oil. Maybe it was wamer outside the first time you check and it read .025qt higher. Just replace the sensor since you are dead set on it being bad.
      01-13-2017, 10:57 AM   #7
pghmailman
Drives: E92 335i xdrive
N55 takes 7 qts with the filter replacement.
      01-13-2017, 11:00 AM   #8
WiL335i
Everyone knows that. I fill it with 6.5 quarts since you never fully drain the whole 7 quarts anyway and overfilling causes leak. I've been filling it with 6.5 quarts for the last 5 years with the level display showing it at Max level. Anyways, I read somewhere that my issue could be from cold weather. So I'll just monitor it.
      01-13-2017, 12:01 PM   #9
weehe126
1161
Drives: 2017 340i
