Will the Eibach pro-kit spings be too low for the e93 335i? *WITH PHOTOS*
01-10-2017, 12:38 PM | #1 |
8
Rep 56
So I Believe I'm on BMW's e93 sport Suspension. I want to install the Eibach Pro-kit as I heard good reviews about them..but i'm worried since I have a convertible (Heavier then the coupe) ill rub considering I have the 19" style 230 wheels. What do you guys think?? I don't want to roll my fenders either. I attached some photos of how I sit now
Eibach Springs drop Front: 1.2 in Rear: 0.6 in Wheel Dimensions Rear: 255/30/19 Front: 225/35/19 Thanks for the help everybody, post pics if you got em! Cheers |
01-10-2017, 12:52 PM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
tons of people do a lot more aggressive drops with a lot more aggressive wheel fitments.. you'll be completely fine. eibach is a conservative drop.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
01-11-2017, 11:00 AM | #5 |
8
Rep 56
Glad to hear that, makes me feel allot more comfortable to finally dropping it. maybe ill install some spacers if all works out. Thanks for the help
01-11-2017, 11:01 AM | #6 |
8
Rep 56
01-12-2017, 04:00 PM | #7 | |
8
Rep 56
01-13-2017, 08:58 AM | #8 | |
59
Rep 457
01-13-2017, 09:59 AM | #9 |
Guest
Rep n/a
Drives:
If that's the case, especially given that the pro-kits have pretty much the same spring rate as your current setup, you could have just gone with lowering perches up front or dropped the front struts lower into the knuckle instead.
If you do decide to put springs on, I hope they're not going on stock dampers either... |
01-13-2017, 10:16 AM | #10 | |
8
Rep 56
Thanks for the input guys! |
01-19-2017, 11:39 PM | #11 |
1688
Rep 3,650
Eibach is the most conservative drop and will be just fine for your vert. Lower with confidence.
Edit: Just saw you're not sure about dampers. Eibachs are the only springs that would be acceptable IMO with stock shocks but if you've got over 60k or so I'd recommend replacing them with shocks of your choice. |
