08 135i: Persistent Cylinder 5 Misfire??
01-10-2017, 09:10 AM | #1 |
44
Rep 193
Title says it all...persistent misfire code on cylinder 5 and just trying to figure out why...below is the list of the things I have replaced in the order they were done and mileage...stock tune and car currently has 61,500 miles:
Plugs: OEM - 59500 Coils: OEM Eldor - 59500 Walnut Blasting: 59800 Replace all Oil Gaskets (oil filter housing, valve cover, oil pan, front and rear main) Coolant, Oil and Filter: 60000 Full OEM Turbo Replacement all lines, etc: 60500 PCV and Catch Can: 60500 VRSF Charge Pipe and Tial BOV: 60500 6 OEM Index 12 Injectors/Decouplers: 61000 Both Precat O2 sensors: 61500 |
01-10-2017, 09:33 AM | #2 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
I put in a brand new coil, still got a misfire.
Replaced the new coil with another new coil - misfire gone. |
01-10-2017, 09:36 AM | #3 |
44
Rep 193
01-10-2017, 11:45 AM | #4 |
193
Rep 666
If the misfire remains, than you might have a bad MOSFET in the DME for that one cylinder. Other than that, it would have to be mechanical.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
01-11-2017, 10:30 AM | #6 |
44
Rep 193
So an update....I moved the plug from cylinder 5 to cylinder 1 and the coil from cylinder 5 to cylinder 2...cleared the misfire code and everything seems ok minus a bit of stumbling at idle but no codes even under WOT...when I floor it in lower gears there is a slight hesitation so I filled up with 93 Sunoco and ran some Techron through it to see if it clears up...next step might be clean both MAP and TMAP sensors??
***Both Plugs and Coils looked normal...slight gas smell, but nothing out of the ordinary...not wet or black*** |
01-11-2017, 10:30 AM | #7 |
44
Rep 193
Another thought: What is the proper way to reset all the adaptations and learned values? INPA? ISTA? Flash a tune on it? Perhaps there are still some out of whack due to the various parts that were replaced?
