Fuel-It Ethanol Analyzer Installation
01-07-2017, 05:24 PM | #1 |
391
Rep 532
This install is on a 2009 135i, but I don't see it being much different for a 335i.
I've had my ethanol analyzer and fuel line kit sitting around for a few months and finally decided to do the install. I was sort of dreading it because I thought id have to pull the intake manifold to change the HPFP line, but managed to do without removal. I followed Steve's videos and the install was a breeze, but there are a few steps which could hang people up. The kit was nicely packaged and everything labeled: High quality stuff, I was definitely impressed. Unfortunately, I was missing two clips for the sensor. I called Steve and he was super professional and apologetic and advised me which clips were needed. I found them at my local auto zone so it wasn't much of an inconvenience, as I had to go there for some supplies anyways. These are the clips: I pulled the engine cover as I thought I would need to remove the intake manifold, but it was not necessary. I removed the air intake assembly, the throttle body, and used a bungee cord to pull all the wiring out of the way. Plenty of room: I was left with enough room to remove the old fuel line and reattach the new one. Tip: Put the clip on the metal line FIRST and grease the fitting, then attach the new line. I wired the sensor to the passenger side DME box and tapped the Red wire with a white stripe, as this is only powered with the key on. I tested it with a multimeter and it shows +-12-14V with the ignition on and +-.01 with the car off. After everything was back together, I filled up at my local station and the result was this: Just to be sure I double checked the ethanol content with my manual kit and its right on. Perfect. I flashed the car to MHD E60 and it runs great, no leaks, no issues. Ready to hit the dyno now so I should have those results posted soon. I couldn't be happier with the kit, the install was easier than anticipated and as usual Steve puts out a quality product. Let me know if you guys have any questions on the install. Last edited by JM98; 01-07-2017 at 05:32 PM.. |
01-07-2017, 05:33 PM | #2 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Nice. How long did it take and is that Fuel-it's recommended power source?
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
01-07-2017, 05:35 PM | #3 |
391
Rep 532
01-07-2017, 06:44 PM | #4 |
Sua Sponte
1299
Rep 2,850
Thanks. I don't run a JB4 either so I wondered if they gave you a alternative location for non JB4 users.
01-07-2017, 07:50 PM | #6 |
391
Rep 532
Chris@VargasTurboTech1933.00 |
01-07-2017, 08:01 PM | #8 | |
1933
Rep 1,532
Although my poor stockers ran 22.5 psi midrange tapered to whatever miserable boost my destroyed wastegates would allow up top for a ton of miles; I think it was something like 11.5 psi at 7200 rpm was all they'd do. lol. |
